Question about Pioneer PL-990 Turntable
PL-88FS with modern HDMI Receiver
I have a Pioneer PL-88FS turntable and need to upgrade to an HDMI receiver. Does the PL-88FS have an internal preamp or will I need to purchase one to connect it to one of the audio inputs on a new receiver?
    Genius:
  • 1,175 Answers
Hi...
If the new receiver doesnt have a specific input in back labeled "phono" , You WILL need a preamp for the phono. Then plug the preamp into the AUX or other available input
Posted on Jan 19, 2009
Just got this used turntable. It's in great shape. Hook it up but it isn't amplified loud enough. I have no ground wire. Help
Turntables, especially older ones, typically do not have preamplifler circuits, which are necessary to bring the output signal from the pickup cartridge to "line input" level for modern amplifiers. You will either need to buy a PHONO PREAMP unit (goes between the output of the turntable and the input of your receiver), or get an older receiver with a (MAGNETIC) PHONO input (internal magnetic cartridge preamplifier).
May 09, 2015 | Audio Players & Recorders
Pioneer turntable to Pioneer VSX 515 receiver
I'm not sure what you mean by "Wot", but I assume you mean that the receiver doesn't have a phono input, as most receivers now a days don't. You will need a phono preamp. Cost is under $25.00. It provides the amplification to be able to use any high level(CD, DVD, AUX, etc) input as well as the RIAA equalization you need to decode the record correctly. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 12, 2013 | Pioneer PL-990 Turntable
My receiver works fine when I plug my iPod into it, but when I plug my turntable in I can't get any sound. Any idea?
The phono cartridge on your turntable puts out a much lower level signal than your iPod. Back when turntables were popular, all receivers had a special phono input to take care of that. Your modern HK receiver does not have a phono input, so you need to get an external phono preamp. Plug the turntable outputs into the phono preamp inputs, then plug the phono preamp outputs into one of the audio inputs on the HK, like where you connected the iPod.
Oct 08, 2013 | Harman Kardon AVR 745 Receiver
I have connected Pioneer PL-990 turntable to SX-255R receiver through PHONO but get static and distortion through speakers. Manual says to connect to AUX not PHONO but cannot see AUX on receiver. Any...
You need to hook it up to another analog input other than the phono input. The record player has a built in preamp, and the receiver's phono input has a separate preamp for non-amplified players. You cannot have the two hooked to each other.
Jan 28, 2013 | Pioneer SX-255R Receiver
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
Re. pioneer pl 990 turntable can the lid be closed
No you cannot play while lid is closed and YES you need an amp/receiver amp
Feb 28, 2011 | Pioneer PL-990 Turntable
How do I connect a technics turntable to an RX-V463 AV reciever? Thank you in advance
Modern AV receivers rarely contain PHONO preamps.
A traditional turntable requires a preamp inline with it to PRE amplify and frequency-balance the minute signal produced by it's cartridge. Most stereo receivers and preamps have Phono connections and internal preamplification strictly for that purpose. Yours does NOT.
A standard turntable will require you to acquire an external PHONO preamp to place between the TT and an Aux connction on the receiver.
Some of the newer turntables come with selectable internal preamplification to solve the lack of it in modern equipment. If your turntable is that type you can select its internal preamp output and run that to an AUX input.
Jan 15, 2011 | Audio Players & Recorders
I hooked up my T.52x turntable to my pioneer vsx-d711 receiver through the RCA input...nothing fancy. I have to turn my receiver volume all the way up in order to hear the records. All the digital media...
The signal produced by a phono cartridge is much smaller than a standard Line Level component produces. That is why the clas of equipment called PREamplifiers existed. Besides PREamplifying it to a level the rest of the circuitry can use it also modifies the frequency curve according to the RIAA standard to produce a sonically flat output. Without either process applied you will have weak, tinny sound from a turntable.
The Pioneer VSX-D711, like most modern AV receivers, is not equipped with a Phono Preamp. If the connector doesn't SAY Phono is won't do Phono.
Dec 28, 2009 | Stanton T.50 Turntable
I need to connect my turntable to my reciever via Pioneer GR-470 pre-amp
no need for phono, you can go to radio shack and get a selection switch to make things easier.
Sep 19, 2008 | Pioneer GR-470 Home Equalizer
Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
No phono inputs?? You will need a phono to line level preamp to use aux input.
Nov 03, 2007 | Audio Players & Recorders
Pioneer PL-990 Turntable Logo
561 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
