Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Icemaker has to be manually turned off
Frigedaire FRS23W3AW6, Icemaker will not shut off automatically when the ice bin is full. Is this normal for this model. Purchased used side-by-side.
  • azmegan1979 Apr 25, 2009
    I bought my bottom freezer brand new and it has had this problem the whole time! I have to turn it off and then remember to turn it back on all the time! Man the problems we have with this fridge! Unbelievable!
  • 410 Answers
Frigidaire has 2 diff i/m units if you have the one that has the i/m along the left hand wall of the freezer then probably you have a broken shutoff cam in the ice maker. solution is replace the i/m
if you have teh model with the icemaker along the back wall. over production of ice is nature of the beast and not really anything you can do about it.
i know neither is solution is great but i hope it helps peyton
Posted on Jan 20, 2009
Do the ice makers shut off automatically when full?
The icemaker has ice level sensor located inside the ice bin. Once ice cubes reaches the sensor, it cuts out automatically and starts once the ice level drops
May 03, 2016 | GE Refrigerators
How do you get an icemaker in a subzero 650 refrigerator to stop making ice when the bin is full?
There should be a metal bar that flips when it hits the ice at a certain level. It should stop automatically. There is a problem with the sensor.
Oct 08, 2012 | Sub-Zero 650 / O Bottom Freezer...
The ice maker stopped making ice one day
A typical problem with these is some type of bin sensor that tells the icemaker that the bin is full. it is usually some type of "arm" that shuts it off when the ice rises to a level that raises the "arm" to "kill" the icemaker
Oct 01, 2012 | Refrigerators
How do I control the amount of ice in the freezer? When I open the freezer door ice pours out onto the floor and in the freezer itself.
That is going to a internal problem in the icemaker,is has a sensor that when it detects that the ice bin is full its supposed to cut off the icemaker so it doesnt overflow and continue making ice such as your experiencing. By replacing the icemaker it will shut off when the storage bin is full.
GENE
Sep 26, 2011 | Refrigerators
Replaced water filter on my Frigedaire refrigerator and it is leaking where the filter is it is making ice when the bar is raised for no more ice it does not lead but when the bar is down to make ice is...
The problem there is going to be one of 2 related causes.
The tube in the back of the icemaker where the water enters it is partially frozen and when the water comes into the icemaker some of it is spraying into the bin instead of filling into the icemaker.Remove the icemaker and check and thaw that tube.
That tube is out of place so once again instead of water filling into icemaker correctly some of it is running into ice bucket instead of icemaker.
Gene
Aug 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 05, 2009 | Whirlpool Refrigerators
Icemaker will not turn on
The very best place to start is with mini manual located inside the kick plate pull it off its the brown/yellow one
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not shutting off
The icemaker should have a bar that is normally in the downward position (ie 4'Oclock) when the bin is not full. The ice falls into the collector and pushes that bar into a horizontal position (ie 3'OClock). These instructions are normally on the ice dispenser section. If the bar is not being pushed up then the icemaker does not know to stop. My only suggestion would be to empty completely the ice maker bin and check that the bar can be pushed from one position to the other. If this happens then try turning on again. I hope this is of some if not much help and good luck.
Jan 27, 2008 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
