Question about Uniden Solara DSC VHF Marine Radio
I have a uniden vhf 580 - my problem is my transmissions have a lot of static and are very weak. i replaced the radio with another one and still have the same issue, then the connector was replaced to the antenna - still the same issue we then replaced the unit with and older vhf and it works perfect. can anyone help me with this headache thanks
4 Suggested Answers
  • 84 Answers
SOURCE: I need new knobs for my uniden solara vhf radio.
You can call Uniden Parts department at 800-554-3988
Posted on Feb 26, 2010
  • 64 Answers
SOURCE: Hi, I have a UNIDEN Solara DSC Fixed Mount VHF
It sounds like your speaker has failed. I would recommend replacing the speaker. You can take the radio to a marine electronics repair shop for the repair and it should be about $75 - $100. If you have any other problems please email me: kevin@sun-me.net. You can always send it to me and we can repair it at my shop.
Posted on Jun 14, 2010
squipps
  • 204 Answers
SOURCE: I have a Uniden 525
Yes if the tip is broken, the antenna will receive, but not transmit properly. The make an antenna that has a 32" stainless steel antenna with a small metal "can". Can mount it anywhere.
Posted on Mar 30, 2011
I have a uniden vhf radio that transmits but won't receive
send it for repair
Uniden - Online Repair Form - Uniden Repair Center - Uniden Americahttps://repair.uniden.com/repairInstruct.cfmRepair Procedure -Brand New Products. Marine Radios=3yr Warranty, Scanner Radios=1yr Warranty. GPS System=1yr Warranty, Digital Camera=1yr. Warranty.
uniden vhf radio Google Search
Jun 24, 2017 | Uniden Radio Communications
Can no longer pick up local channels. Any ideas why?
weak batteries,possible bad antenna connection(remove and re install to get better connection)
Jan 23, 2016 | Uniden BC72XLT Handheld Scanner
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
Static noise rx
Check your batteries. Static can be a sign of a bad or low battery. Swap batteries between the units to see if the problem moves to another radio.
Also, check your antenna and antenna connection.
Best regards.
May 13, 2013 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
I have a Uniden 525 fixed mount 2-way VHF radio. It has power and picks up weather with the shakespeare antenna. However radio checks have failed and i don't receive anything either. The antenna's tip is...
Mar 28, 2011 | Uniden UM525 ES Series VHF Radio with...
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
Mar 24, 2011 | Uniden Solara DSC VHF Marine Radio
With engine running on boat, radio transmitts with
This is almost always caused by a poor ground. I would suggest you run your ground wire (larger the better) back right to the negative terminal of the battery.
Hope this is helpful.
Jul 14, 2010 | Uniden Solara DSC VHF Marine Radio
Which antennae to use with a Uniden Oceanus radio?
Marine two way radios operate on 156 MGZ. You have to use an antenna desinated for that purpose. Type marine vhf antenna on google search and it will pop-up lots of web sites.good luck
Jul 21, 2009 | Uniden Solara DSC VHF Marine Radio
Uniden VHF Hand held Radio HH940
There are several avenues for you. 1. do a serch on ebay for the battery. 2. try your local two-way dealer or 3. go to Unidens web site.
Pat
Aug 16, 2008 | Uniden HH940P Handheld, programmable...
Uniden Solara DSC VHF Marine Radio Logo
87 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Mike Marcotte
Mike Marcotte
Greg Cann
Greg Cann
Are you an Uniden Boating Expert? Answer questions, earn points and help others
