Question about Water Heaters
Our church baptistry heater will come on for a few seconds and then goes off.after a little bit I can hit the reset button but will only come back on for a few seconds.then the red light goes out agai
When I first turned it on,the red light came on for maybe 20 seconds,and then goes out.when I let it sit for awhile I can turn it on and it does the same.the last time it was set on 9,and when it went out I set it to 10 and the light came back on for a few seconds.
  • Water Heaters Master
  • 5,089 Answers
1) For tank-type gas water heaters:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Re-post question on fixya or Tank forum and include information that shows on product label usually located on side of unit, so expert can determine which product, and what error codes and controller are revealing.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Jan 01, 2013
  • 70 Answers
SOURCE: A2 error on Bosch tankless water heater
  1. Check continuity of the flue gas limiter (see Fig. 63, page 46 of manual). Go to steps two and three to determine air box temperature sensor fault and replace it.
  2. Check for flue gas leakage around the top and bottom seals of heat exchanger as well as the viewing window.
  3. Check that venting is within specifications (see Section 3.3 of manual). Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure.
  4. Check that flue gas limiter connector and spade connections are secure.
  5. Unplug heater and check the two main plug connections inside the control board.
Posted on Jan 23, 2009
  • 659 Answers
SOURCE: How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Posted on Apr 02, 2009
  • 3 Answers
SOURCE: Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Posted on Sep 10, 2009
mrhotandcold
  • 248 Answers
SOURCE: rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Posted on Oct 31, 2009
  • 138 Answers
SOURCE: i have a richmond 5v40-36f water heater & when
Do you have a natural gas or propane water heater. You could possibly have a dirty valve which stops the flow of the gas. Has there been a change with the environment of the water heater. Check for the draft and back blow of the available air. If the water heater is over 6 years old maybe it is time to replace the unit. Good Luck
Posted on Jan 08, 2011
Testimonial: "Thank you for the info..but i thought as long as it doesnt leak it should still be good & it is natural gas...2003 richmond 5v40-36f"
My line water heater turns off after a few minutes
if u are hitting the red button and it is a heat pump hot water system it means that the unit is going out on high pressure ( the red button is a high pressure manual reset button) this could be caused by a few things could be over charged ( but unlikely if no one has touched it recently) a solenoid isnt opening or there is a blockage in one of the TX valves. if the button u are pushing isnt in the pipe work and it is on the compressor it could be an over temp switch on the compressor ( unit could be short of gas) just need a little more info to pin point the problem.
May 21, 2014 | Stiebel Eltron Water Heaters
How do I troubleshoot a 6kw 240 volt circulation heater. This heater is on a baptistry; they fill it up before service starts and use it 90 to 120 minutes later and water is still cold.
It is very possible that you just are not giving it near enough time...
I have worked on them before and they do not heat the water very fast....
you will need to give it at least 12-24 hours to heat the baptistry properly...
That heater will only heat about 30-35 gal./hour....on a 50F rise in water temp. ....figure how many gallons you have there and then do the math...
heatman101
Apr 13, 2011 | Little Giant Water Heaters
AFTER LIGHTING MY RICHMOND 6G40-36F1 WATER HEATER IT LIGHT FOR A FEW SECONDS AND THE FLAME AND THE PILOT LIGHT GOES OUT. WHAT CAUSE THIS TO HAPPEN?
There is air in the gas line. The best way to get the air out, is with the gas on, loosen the nut that attaches to the gas valve and make sure you can smell a little gas, then reattach the gas line, making sure everything is tight, and then relight the pilot making sure to hold the pilot light button down for at least 1 minute. Please rate
May 24, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Tankless Paloma NG hot water heater shuts down
have you checked the error codes on the heater?
you can do this by powering off the controler and pressing the up and down keys for a few seconds. this should take you into the diagnostics mode scroll using the up and down keys till you find the one that has the letter E on it and that will give you the last 8 error codes write them down and get back to me
Jul 16, 2009 | Rheem Tankless Hot Water Heater...
Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Mar 06, 2009 | General Electric GE SmartWater Household...
Jan 22, 2009 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
62 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
