Question about Dryers
No heat electric Whirlpool Ultimate Care II
Cleared out all vents, and even run it with the hose off the back and no heat....I could not find any clogs to cause the problem either. it blows air fine but cannot heat up. I removed back panel but have no clue at what I am looking for...
  • dbudrich Jan 18, 2009
    thanks for the reply....LEQ9508PW1
  • 5,911 Answers
The following link will give you some advice on a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. Most dryer heat related problems are caused by poor air flow. I know you mentioned cleaning out the vents, but did you ensure the ducting is clear all the way the where it exits your home? Have you also verified there are no kinks or excessive bends that may restrict air flow? Just some addtional things to consider...
If you have good strong air flow, but no heat, you probably have a failed internal component. If you will post back with your complete model number (located around the door opening on most models) I can determine how your dryer is contructed and let you know how to identify the internal components. Please let me know. I hope you find this helpful.
Posted on Jan 18, 2009
  • Jeff Rockwell
    Jeff Rockwell Jan 18, 2009
    Okay, your dryer heating circuits are in the back of the dryer. Should be no surprise to you at this point. As viewed from the rear:
    1. The heating element is located on the right hand side inside the heater box.
    2. The Hi-Limit Thermostat is small round component located nearest the heating element ceramic terminals.
    3. The Thermal Cut-Out (TCO) is a small round component located at the top end of the heater box.*
    *NOTE: If you have a dryer no heat problem, this is the usual component that fails. If the TCO is bad, it is highly recommended that you replace the Hi-Limit Thermostat at the same time. In many cases the manufacturer sells these components as a set. Failure to do so may results in premature failure of any replaced components.
    On the left hand side at the bottom, is the blower fan housing. The Thermal Fuse is the white (sometimes gray) plastic component on the blower fan housing. If this component fails, the entire dryer will stop. No heat, or spin. The component adjacent to the thermal fuse, is the internal bias (or operating) thermostat.
    If you go to searspartsdirect.com and type in your model number, some excellent exploded view diagrams are available to assist you. The heating circuits are listed under the "Bulkhead Parts" heading. Your parts are listed as the following:
    Item 7 - Thermal Fuse
    Item 8 - Internal Bias (operating) Thermostat
    Item 9 - Thermal Cut-Off (with Hi-Limit Thermostat) Kit
    Item 15 - Hi-Limit Thermostat
    Item 17 - Heating Element
    I recommend you check the resistance of the TCO to see if it reads a short (0 ohms). If you get an infinite reading, the TCO is blown an requires replacement. Make sure your measurements are accomplished with the dryer UNPLUGGED and the wires to the TCO disconnected. Follow up by checking the resistance of the heating element in the same manner. If the TCO is bad, purchase item 9.
    You may also try looking at appliancepartspros.com. They sometimes have the same parts listed at a better price.
    If you have questions, or require additional assistance, please let me know. I hope this helps you.
2 Suggested Answers
catriver
  • 878 Answers
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Posted on Jan 01, 2008
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer not drying in alloted time
there is a thermostat. it usually is located on the heating element housing
May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Have heat & tumbling but will take 3 hrs to dry a load/ no jeans
Likely that your Dryer vent is clogged up. Especially if its long. Check that by hooking up a shopvac to one end with duct tape to seal any air leaks between the vent pipe and the vac hose. Turn it on and check the other end of the vent pipe for suction. If its faint then there may be a crapload of lint in there or a birds nest. Compressed air in the pipe with an agitating device may work or shopvac hose if run is short. Be prepared for a mess on either end.
Heather
Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II dryer will not dry clothes
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool super cap. electric dryer imperial
element or thermal fuse at top of element housing most likely if either is bad ck vent system before using very long plugged vent can cause overheat long dry times and premature failure of element
Apr 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
3,882 people viewed this question
Top Dryers Experts
