Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch dishwasher model shy56a05uc/14 door wont latch
Cannot get door to connect/latch to run cycle. Lights will still come on and it can be run but of course water comes out as door not "locked"
I tried the various solutions on this site with no success. Finally I wedged it shut with a nice clear plastic door stop. Worked perfect (who cares if people think it looks funny, I am not hand washing and still am not out any extra dollars)
Posted on Jan 16, 2013
  • 311 Answers
SOURCE: Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Posted on Nov 28, 2008
SolutionGuy
  • 331 Answers
SOURCE: bosch dishwasher motor keeps running no water
Hola Lewis!
This is such an easy repair, you'll be shocked and surprised! The reason this is happening is that the computer or timer has detected a "flood" condition and has permanently energized the drain pump to clear the "flood".
What you'll need to fix it...
1.) Shop-Vac (for vacuuming water) with a crevice tool (like one of these)
2.) T20 Torx bit with a driver. Torx sizing here. (You can get a set at Home Depot or Lowes)
All you gotta do now is get down on the floor and remove the kick panel. Then remove the screws holding the water valve and lift it up out of its' plastic holding. Now your shop-vac w/ crevice tool can be used. Stick the crevice tool in there (about 10") and vacuum up all the water that's been trapped in the basin. (you may need a flashlight to see what's going on back in there...) After the water is gone, your DW will work fine.
Here's how it works... About 10" behind the inlet valve is a "float" made of styrofoam. When water gets into the basin, the float rises and eventually trips a "flood condition" switch. This switch shuts the unit down and will only allow the drain pump to operate. So what you want to do is get the water out of the basin.
There may be a reason for the basin flooding, though. Suds (caused by too much (or the wrong) detergent), an actual water leak from the valve, etc... So after you get the water out of there and the unit is working again, you may want to monitor it (like, only run it when someone is home) for a while just to make sure that a real flood does not occur.
Hope this helps.
SG
Posted on Mar 23, 2009
howapp
SOURCE: My SHY56A05UC Basch dishwasher runs and dose not shut off
The dishwasher is stuck in drain mode because there is water in a catch leak area underneath, it may have been caused by soap suds over flow or disposal backup. Remove bottom kick plate and vacuum out any water, then run dishwasher again and look for water leaks.
Posted on May 21, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
  • 457 Answers
SOURCE: the dishwasher is stuck in the drain cycle Bosch SHX46A
you have a leak,or the something has the float stuck in the open position. when water gets in the base the float raises and the uni automatically drain until the water is out of base. if this helps post a 4 thumbs up post
Posted on Feb 28, 2010
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher model SHY56A05UC/14 door wont latch. It will run but of course water comes out as it is not locked.
That sounds more like a gasket problem then a lock problem. Check the rubber seal on the door for damage. Even a small imperfection in the seal can cause the door to leak even though the lock is engaged.
Or is it that the door just won't close at all? If that's the case, check the locking mechanism to see if there's anything jammed in there. If so, remove it and that may fix the problem.
Jan 01, 2013 | Bosch Dishwashers
Bosch dishwasher, SHE43M 30" built-in, door won't latch closed, yet can still start cycle.
check latch on dishwasher side of the unit to make sure it has `nt got loose they make them so you can remove them when the unit is discarded so children can`t get trapped in side
Nov 06, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher door leaks
Hi have you adjusted the door striker on the top part of the dishwasher? This is the part that the main door latches onto and can be adjusted in or out!
Feb 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Have a Bosch shy56a05uc dishwasher that suddenly stopped working to a point. I believe it is related to the door latch switch, because I don't feel the door securely latch shut when I close it, and I also...
Does your dishwasher electronic control or mechanical timer? if mechanical timer, I encounter a similar problem n change the mechanical timer. that problem solved.
Prince P
Jul 23, 2008 | Dishwashers
Bosch SHY56A05UC/14
There is a pass through the lower back side of the dishwasher that also has a restraining device to prevent drain hose from being pulled off of drain pump. After passing hose through this opening, connect hose to drain pump. Note: there is another restraining device built into lower plastic housing which has a finger notch to accept hose and keeps the drain hose engaged in to drain pump by not allowing hose to back out of drain pump/ hose interface.
Dec 01, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Nov 10, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
122 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
