Question about SNK Magnavox 42MF231D 42 in. Plasma TV
Will not power up or go on and makes a clicking noise
  • SNK Master
  • 933 Answers
I would suspect faulty capacitors in the power supply
Posted on Jan 01, 2013
  • 1 more comment
  • capricornbil
    capricornbil Jan 01, 2013
    where do I get capacitors for the power supply?
  • Back2life Electronics Jan 01, 2013
    Radio Shack or any electronics parts store. But I would suggest you remove the back cover and check the power supply board for any capacitors with bulging tops before buying anything.
    If you find bulging capacitors, you will need to replace them with the same uF of capacitance, and at least 105 degree C temperature rating. It is ok to go up in voltage rating but never go down in voltage rating.
Delonghi PAC AN140HPEC clicking noise.
1) test the mounting pads and bracket for worn
2) The compressor and motor are powerful device for make enough noise.
3) Try to adjust it very well in the frame windows, for vibration.
God bless you
Jun 22, 2012 | Heating & Cooling
Lg 50PG20 IS MAKING A CLICKING NOISE AND WONT COME ON
Hello
Check the power supply regulator board for the fault.
Mar 03, 2012 | LG 50PG20 50 in. Plasma HDTV
Computer is making a clicking, and beeping noise
sounds like hard drive failure , but may be settings in cmos
Apr 22, 2010 | Dell Inspiron 531s Desktop Computer
Whenever i go turn the tv on its starts making a clicking noise.
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Mar 17, 2010 | LG 60PB4D 60 in. LCD Television
Pump makes clicking noise when powered up ?
Clicking?... not knowing which clicking noise you are hearing, I will run down the most likely on a new pump.
1. When wiring the motor you may have left a wire in close proximity to the centrifical start capacitor switch. It spins at high RPMs and can be hitting a wire not properly tucked in
2. Most pool pumps are dual voltage. If you wired motor for wrong voltage than that being delivered, the motors can sometimes make noises. Clicking isn't most common, but the vibrating hum of incorrect voltage might be interpreted as a clicking noise.
3.check to make sure no wire ties, or plastic stringy tag holding devices were left in the pump intake basket.
Aug 23, 2009 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Will not power on, makes a click noise only
if you dont know take your tv to w/shop, let the tech test the output of that power supply.
he has to test the following, switch contacts,power transistor,diodes, and resistors less than 100 ohms.
your set will be okay again.
if you want it to be move perfect test capacitors as well, and change all electrolitic, on the power supply. this will make your tv stay longger and perfect.
Apr 29, 2009 | Sony Televison & Video
Wont power on makes clicking noise
Replace any swolen capacitors in power board.
Apr 25, 2009 | Televison & Video
Clicking noise on power on and every print
This can be all that is pleased , main reason there is defect of lubrificant there where this it is necessary, recommend you to apply to nearest service.
Mar 05, 2009 | Brother MFC-8460N All-In-One Printer
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
SNK Magnavox 42MF231D 42 in. Plasma TV Logo
29 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
