Water softener whirlpool whes30 water level too high
Water is about 8 inches above salt level
5 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: Whirlpool Duet GHW9400 Water Level Seems Too Low
Scott,
Believe me, if the water level were ever several inches above the glass, you'd know about it 'cause it would flood your laundry room. Seriously. See? That rubber door boot/seal is not water tight (like a submarine) when the door is closed and locked, it's water "resistant".
Front loaders often appear as though the level is low, but they are designed this way. The clothing actually tumbles through the water as opposed to soaking in water like a top loader.
All of that to say that you have nothing to be concerned about. Your water level is fine.
SG
p.s. If your water level switch had failed, as you suspected, the water level would be too high and leak out the door.
Posted on Apr 03, 2009
  • 686 Answers
SOURCE: water still in tub water level light blinking
GO TO www.repairclinic.com AND LOOK FOR PART 541811 IT MAY BE CLOGGED AND NEEDS CLEANED OUT THIS IS A LINT CATCHER FOR WASHERS
Posted on Apr 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: how do I adjust the quantity of salt used for the
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
richroth
  • 9472 Answers
SOURCE: there is water in the main tank on my whirlpool whes40 water softner
What is the model number of your unit?
Posted on Nov 24, 2012
How do I reset salt level
On the left hand side should be button marked salt level, after adding product,on side of brine tank are numbers in yellow telling you the level,push salt level button to the number shown on side of brine tank. Note: do not fill over brine tank, I suggest to fill to level 6 or 7..
Oct 31, 2014 | Kenmore Ultra High-Efficiency Water...
Tip
Water softener salt bridging
One of the most frequent problems with water softening systems is salt bridging in the salt/brine tank. There are several reasons for salt bridging to occur. This generally occurs when pellet type salts or potassium chloride is used to regenerate the water softening system. Pellet type salts contain binding agents that in turn give the salt a very starchy consistency when wet. As water evaporates in the brine tank the pellet salts partially dissolve, bind together and form a "salt bridge" in the tank. Potassium chloride (Kcl) acts in the same way. Excess water in the salt tank, with high salt levels, can also cause salt bridging. Improper softener brining and lack of proper brine refill will cause bridging to occur as well.
What is the best way to alleviate these problems?
1. When using pellet type salts or potassium chloride only keep the salt tank about 1/2 full. This prevents too much compaction of the salts and helps to prevent bridging. When using potassium chloride get the salt tank off the floor on a wooden platform to prevent wicking of moisture from concrete floors.
2. Use a high grade of salt. Most water treatment dealers use either
DuraCube or HardiCube water softener salts produced by Cargill Corp.
Cargill has a link to find dealers in your area.
https://saltapps.cargill.com/cargillsalt/product_locator_new.asp
Solar Salt is another option as the crystal structure is very hard and virtually impossible to bridge. This is also available from many Cargill salt dealers and in stores.
3. Let the salt tank run down to 80-100lbs of salt or potassium a couple times per year to help prevent buildup of dissolved salts in brine tank.
4. Yearly maintenance of the water treatment system helps also. Restrictions in the brining system (injector/eductor assembly) caused by sediment and oxidized iron buildup cause improper brining and too much water in salt tank during refill. Have this assembly cleaned yearly. Have the water tested to see if the water chemistry or usage have changed and adjustments to the system are necessary.
5. Avoid using rock salts to prevent buildup of sediment in brine tank (which causes service problems).
Practice these tips and you will have fewer water softener problems and more consistent quality softened water.
I wish you good water!
H2O Services
on May 17, 2011 | Water Dispensing & Filtration
Culligan water softener manual
You are likely using a rock salt and what you are seeing is a build up of dirt and fine sand because rock salt isn't clean... it's got rocks in it. Clean your tank out and rinse it thoroughly with a hose. Be sure to clean out your 3" tube (brine well) and under the salt platform if you have one. Start with a clean salt like System Saver II or Crystal Plus. Never fill your salt tank over half full. Always let your salt be used down to the water level. IF the salt at the water level is soft and pasty don't add more; tip the salt tank until the salt is raised along one side or corner to above the water level when you stand the tank up carefully. This will allow all the water in the tank to become brine (saturated solution).
IF you are using potassium instead of salt, the brown is a natural component. Don't worry about it although it never hurts to clean your brine tank yearly.
Aug 04, 2014 | Water Dispensing & Filtration
Why is water standing in brine tank of whirlpool whes30 water softener
Brine tanks are normally always precharged with water ready for next regeneration. It also allows contact time to ensure correct brine solution.
Sep 08, 2013 | Home
Cloudy/salty water, stuck bypass valve
water in your salt store is normall. it is commonly called brine. this is purely a cleaning agent of your water softener to regenerate the media. you do not drink this water nor does your water pass through this. it is only pulled through into the unit when regenerating.ie. this piston is in a position which allows the water to flow through a v enturie pulling the salt. water will sit in the brine tank always to be ready for the next generation and to be at the correct brine dilution so it's important to maintain the salt level above the water level. cloudy water is nirmally air bubbles which should settle out within a couple of minutes . if it tastes salty I suspect your regeneration waste water is contaminating your supply feed. like seeping back into well or tank .
Apr 18, 2017 | Water Dispensing & Filtration
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My salt brine tank fills with water. What could be the problem? How do I fix it?
That is normal in the operation of a water softener.
The water soaks the salt to liquefy it so it has salt water to flush the resin to make it let go of the lime deposits.
That is over simplified but is working like it is suppose to.
Mar 11, 2011 | Plumbing
My high salt light keeps coming on and no salt has been added
The only fix for this is to remove some salt. You do this by removing some of the water. Without the benefit of a proper test kit, it is difficult to tell you how much water to remove ... I would suggest you drop the level 8 to 12 inches, add fresh water and see what happens. If the salt is still too high, wait a day and remove another 8 to 12 inches.
Thanks for your interest in FixYa.com.
Aug 20, 2010 | Intex Automatic Salt Water System for ...
My Dishwasher leaves a white film on dishes.
check inlet water quality. If more calcium deposits in the water this could happen. Try using water water softeners.
If provision for dish washer salt check and add salt. ( not kitchen salt )
Finally check whether rinse aid compartment is filled with the liquid. If you are tablet, extra rinse aid not needed. Try all the above.
Aug 17, 2010 | Whirlpool Dishwashers
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
