Question about HP PSC 1350v All-In-One InkJet Printer
Keeps blowing at fuse box
Wont pick up paper ,then kepted tripping the household circuit breaker
    Filmmaker:
    Uploaded 5 video answers.
  • 45 Answers
The unit is either faulty and may have an internal short or the circuit is overloaded.
Posted on Jan 01, 2013
  • Michael Nieuwendijk
    Michael Nieuwendijk Jan 01, 2013
    Thankyou ,yes I have an overloaded circuit
Mt Moffat clothes dryer keeps blowing thier own fusses
You have heat sensors on the Heating Element. If one allows the heat to get to high it can trip the Breaker. It more than likely is a bad Circuit Breaker in the Breaker Box. These can go bad. It is a Double switch, one is for the heat, one is for the Motor.
Jan 18, 2013 | Dryers
Light downstair keep tripping our fuse box
Is it really a fuse box ? or breakers ? If nothing is running on that circuit ,you probably have a short circuit , the fuse or breaker is saving you from a fire.
Apr 30, 2012 | Cars & Trucks
My maytag front load dryer turns on and runs,it does not blow any hot air
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer runs but dosn't heat any ideas would be appreciated
Visually verify household fuse blown or a circuit breaker tripped.
The drum may be turning, but you may not have heat. Electric dryers use 2 household fuses or circuit breakers. Replace the fuse or reset the circuit breaker.
If the problem continues, call an electrician.
Rating the solution is highly appreciated.
Jun 16, 2010 | Miele Novotronic T220 Electric Dryer
Won't heat
Jun 16, 2010 | Whirlpool LER5636P Electric Dryer
Dryer heat not working
Jun 16, 2010 | Whirlpool GEW9200L Electric Dryer
I have 60 amp circuit breaker on my electrical a/c heater with a 45 amp fuse. I had the unit for 7 years with no problem. This month the 60 amp circuit breaker keeps tripping when the heater goes off. The...
You're unit is a 31/2 ton according to the numbers.Normally, breakers will only be in a half way posistion when tripped. Yes, under most conditions, the fuse will blow before the breaker trips. I have seen this many times, the breaker may be weak, burned, loose wires and so tighten wires, check the condition of the breaker.It sounds like the breaker even though it is 60 amps, is the problem and you should replace it with out hesitating. This will solve you're problem. When you pull the breaker out, look at the metal clips that snap in on the buss bar to see if they have been overheating.And the buss bar its self. You will know. I am sure this will take care of you're problem. Good Luck,
Shastalaker7
Dec 07, 2009 | Goodman CKL42AR42 Air Conditioner
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
HP PSC 1350v All-In-One InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
