How do i do half load or is it automatic for the weight
    Scholar:
  • 133 Answers
Depends on whether your machine has this function as newer machines are more economical in their use of water they already don't use as much as old machines used to so it may not be a function on yours.
Posted on Jan 01, 2013
What does load sensing mean
Load sensing means that the machine will automatically set the load size determined by the weight of the load at first fill.
Jan 16, 2015 | LG WT5001CW Washer
How do i do half load or is it automatic for the weight of clothes
It depends on the machine, but most have some form of knob or button that adjusts the water level, though some of the newer machines will do it automatically.
Jan 01, 2013 | Washing Machines
Can't automatic adjust rear shocks
Actually, the Goldwing doesn't have adjustable shocks. What it has is a load levelizer and in order to adjust it for the various weight loads it needs to be on the main stand. Viewing the display will let you know the weight level it is set at. If that doesn't work, you will need to check for a blown fuse.
Sep 26, 2012 | 2008 Honda GL 1800 Gold Wing
What are the fluid capacities and types/weights for a 2001 KIA Optima 4-dr. with a L4 gasoline engine and 4-spd. automatic? Need exact capacities for engine, coolant and transmission, as well as oil...
Hey, i have been using 5W-30 for the longest time and its been fine, it should say in owners manual but dont have it. The capacity should be around 4 quarts give or take half a quart, just make sure u add in as needed and dont overfill it. If you buy one of those yellow gallon or so jugs of 50/50 coolant, i used about half of that in mine. Hope that helps, have no idea for transmission. I would just leave the transmission fluid in since im guessing u have a lot of miles on the car.
Sep 12, 2011 | 2001 Kia Optima
My pool cleaner only sweeps the deep water zone. It never comes up to the shallow half part of the pool. By the way, the approximate size of my pool is 18 ft x 36 ft.
This should be an easy problem to fix with this type of automatic pool cleaner. Add return diverters or divert return inlets downward. This will use flow to move cleaner to opposite end. Move hose weight away from cleaner head slightly. You might also have to add additional hose weights.
Apr 17, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I need to know what is the maximum weight for a ford fiesta
I don't think that anyone publishes that number but, I would not consider putting anything more than half or less of the average weight of max passenger load (assume the average passenger at about 165lbs) Reasoning behind this is that weight distribution is an important factor in how your vehicle handles. By adding weight above the vehicle, you are radically changing the center of gravity,(creating a "top-heavy" situation) making the possibility of a roll-over greater.
You also need to consider the weight of the load you are carrying inside the car. You don't want to exceed that number overall or it will cause "bottoming" and suspension damage.
So, if packing for a trip, keep the heaviest items inside the passenger compartment where the weight is between the front and rear wheels, next heaviest in the trunk and lightest in the roof addition. this will keep the roll center as low as possible and front to back weight distribution even. You may want to raise your tire pressure a few pounds as well to prevent a tire failure from overloading. Max pressure and weight load is marked on the sidewall of every tire.
One other item worth mentioning is to check your roof box after the first thirty miles or so. make sure it is still secure...I see far too many lying on the side of the road, likely because someone did not do that.!!
Good Luck
Sep 16, 2009 | 2005 Ford Fusion
Washing machine vibrates bad in spin cycle
dont put full load please check it with half load or add water excess
Sep 15, 2009 | Kenmore HE2 Plus Front Load Washer
Towing capacity for an Isuzu I370 pickup
As listed in the owners manual.
Weight of the Trailer
How heavy can a trailer safely be?
It depends on how you plan to use your rig. For
example, speed, altitude, road grades, outside
temperature and how much your vehicle is used to
pull a trailer are all important. It can also depend
on any special equipment that you have on
your vehicle, and the amount of tongue weight the
vehicle can carry. See “Weight of the Trailer
Tongue” later in this section for more information.
Maximum trailer weight is calculated assuming
only the driver is in the tow vehicle and it has all
the required trailering equipment. The weight
of additional optional equipment, passengers and
cargo in the tow vehicle must be subtracted
from the maximum trailer weight.
The following charts show how much your trailer
can weigh, based upon your vehicle model
and options.
2WD Extended Cab Axle Ratio Maximum Trailer Weight GCWR*
Automatic Transmission,
2.9 L Engine 3.73 3,100 lbs (1 406 kg) 7,000 lbs (3 175 kg)
Manual Transmission,
2.9L Engine 3.73 2,100 lbs (952 kg) 6,000 lbs (2 721 kg)
4WD Crew Cab Axle Ratio Maximum Trailer Weight GCWR*
3.7L Engine 3.73 4,000 lbs (1 814 kg) 9,000 lbs (4 082 kg)
*The Gross Combination Weight Rating (GCWR) is the total allowable weight of the completely loaded
vehicle and trailer including any passengers, cargo, equipment and conversions. The GCWR for your
vehicle should not be exceeded.
Aug 26, 2009 | 2006 Isuzu I 370
I need an instruction manual for an Omega WD 1052 washer, please
I have searched everywhere as well, and no luck. I did find a bit of information on it which I have pasted below -- it might help a bit if you want to play around with it.
I would also suggest reading manuals from other wash/dryer machines to get an idea how they work--then maybe you can figure yours out by just pushing the different buttons and seeing what the display says. (At the end of this post, I have pasted a link to a different Omega washer/dryer -- perhaps you could skim it and see if it is at all similar to yours.)
Information About the Omega WD1052.2 washer dryer
THIRTEEN PROGRAMME:
The WD1052.2 is sequentially segmented into thirteen rotary positions for both easy and logical programme selection and for the quick identification of programme progression.
Choose from one of three wash sequences:
Programmes one through five are for the heavily soiled, more colour fast fabrics and daily wear.
Programmes six through to ten look after the slightly soiled, synthetics and for delicate items.
Woollens are exclusively washed on programmes eleven through to twelve.
CONDENSER DRYING:
The WD1052.2 can automatically dry a half a load of washing at the end of the wash programme provided the half load button is selected and a drying time is set on the centre control dial.
At any time the WD1052.2 can be regarded as an independent dryer, that is, a wash programme does not have to proceed into the drying stage. An example would be drying damp clothing or toweling from the bathroom. Simply choose a STOP position after either 5 or 10 on the programme dial. On the centre dial choose either full heat, the pink zone, or half heat, the green zone.
Another useful variation of the WD1052.2 is the ability to choose final spin only followed automatically by condenser drying. Having completed a hand wash, for instance, simply load the clothing and select final spin, 5 or 10 with the half load button selected and drying time set.
Whenever the WD1052.2 is in the drying mode the load can be easily accessed at any time via the porthole. The drying will automatically resume once the door is reshut.
Specifications:
Freestanding or Built-in
5kg (11lb) dry weight Capacity
2.5kg (5 1/2 lb ) dry weight condenser
13 Programmes
40 minute Fast Wash
Special universal 2B programme
Dedicated woollens cycle
Independent wash temperature control
1000 or 500 r.p.m spin speeds
Half load Economy selections
Drip dry no spin programming
Anti crease hold in final rinse Selection
Extra rinse option
Two drying heat settings
Stainless steel inner and outer wash drums
Two minute delay safety door release
Built-in heating element
Front mounted easy access lint/forgin matter
inspection
Automatic balancing of wash load
LINK TO A DIFFERENT MODEL:
http://www.omegaappliances.com.au/Documents/Document_205.pdf
Good Luck--I hope you get it working!
P.S. If you find this information useful, please remember to rate me! Thanks!
Mar 18, 2009 | Washing Machines
Squeaking due to weight of clothing
When you need this kind of noise and there is no abnormal vibration, then it depends on the drive pulley that pull the belt.
If it depends on the weight, and you get vibration it can also depend on bad dumper pads.
Here you can locate dumper pads and drive pulley below the tub.
Both parts are serviceable, repair should not be expensive.
If you need to contact a repair service, you can use the number listed on the owner manual.
Sep 05, 2008 | Hotpoint NWSR483EBWW Electric Dryer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
