Question about Xantrex Technology RS3000 Sine Wave Inverter / Charger
Xantrex battery sensor problems
My xantrex RS 3000 can'T reconise the battery temp sensor on the screen, and the battery are too low all time and can't charge , the hook up is plug in 15 amps, 120 volts
3 Suggested Answers
  • 4 Answers
SOURCE: Is true sine wave better than modified sine wave.
To make a long story short, I've only had trouble with the Xantrex XS-400. There's only one review at Amazon and it's mine! Have a look.
http://www.amazon.com/XS400-400w-Sine-Wave-Inverter/dp/B000A7MW5E/ref=sr_1_1?ie=UTF8&s=sporting-goods&qid=1256963563&sr=8-1
Richard
Posted on Feb 14, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I got an error of ER 05. What does that mean?
Hi and welcome to FixYa, I am Kelly.
E05: Flashing Fault LED: Flashing Alarm: Beeping = Output on inverter is shortcircuit
- Disconnect your output terminals and see if you still have the code. This is telling you there is an external short.
- If you still have the error with the output terminals disconnected start looking for internal inverter shorts to the output connector. (Chaffed wire / hot wire signs / internal + lead ground)
- If you have Circuit Breakers / fuses on your output side open all the CB/s or remove all fuses then turn on the CB's / install fuses one at a time until you note the Er05 error. Then troubleshoot the shorted circuit with an Ohm Meter.
Thanks for choosing FixYa,
Kelly
Posted on Mar 19, 2011
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
My water temp keeps showing 197 or higher temp. The air temp shows the correct temp
You need a new water temp sensor. This is an extremely common problem with the RS system.
Oct 21, 2013 | Jandy AQUALINK RS TELELINK KIT
I have a Xantrex 2400-12 two years old, installed off grid in a vacation home in Mexico, a service call is not an option. The inverter quit working, flashes "888" and shuts off. I have a trace...
First off I am not in this for the money. If your not satisfied with the information below simply reject the solution so that you can hear from other experts.
The 888 flashing is telling you that the inverter has lost DC power momentarily. This can be from broken strands in the battery cables or an internal wiring problem in the inverter. Check the battery cables for corrosion. Remove the terminals check for battery post corrosion and visually inspect each bable to terminal connection from the battery connector to the inverter DC Power connections.
Here is something to keep in mind. A DC power cable only needs one tiny strand of wire to indicate voltage on a meter. However, if there is any load on the AC side that tiny strand of wire that is giving you the proper DC reading may in fact drop well below 10.5 V DC and simply cause the unit to automatically shut off even with no load.
Explain your situation to Xantrex using the link below and they may be able to help you due to the fact that you do not have a local "post warranty service provider" in Mexico:
If your product requires troubleshooting or warranty service, contact your
dealer.
If you are unable to contact your dealer, or the dealer is unable to provide
service, contact Xantrex directly at:
Direct returns may be performed according to the Xantrex Return Material
Authorization Policy described in your product manual. For some products,
Xantrex maintains a network of regional Authorized Service Centers. Call
Xantrex or check our website to see if your product can be repaired at one of
these facilities.
What proof of purchase is required? In any warranty claim, dated proof of
purchase must accompany the product and the product must not have been
disassembled or modified without prior written authorization by Xantrex.
Proof of purchase may be in any one of the following forms:
• The dated purchase receipt from the original purchase of the product at
point of sale to the end user, or
• The dated dealer invoice or purchase receipt showing original equipment
manufacturer (OEM) status, or
• The dated invoice or purchase receipt showing the product exchanged
under warranty
Telephone: 1 360-925-5097
Fax: 1 360-925-5143
Web: www.xantrex.com/support
customerservice@xantrex.com
The owner's guide is here:
http://www.xantrex.com/documents/Power-Inverters/Xantrex-Inverters-Digital/XPower_200-400-800_Digital(975-0176-01-01_Rev-B).pdf
Kelly
Jan 16, 2011 | Xantrex Technology Trace Series Inverter /...
Xantrex model rs2000. just purchased used. owner said all worked. got wired up, charger does not operate, shows no external power source, (led not lit). checked power to unit, at 119-123 acv.. inverter...
If it shows NO external source, then this is most likely the best place to look to find out why not?
http://www.ehow.com/how_7519715_troubleshooting-ac-inverter.html
Now above is a link that show you how to troubleshoot an AC inverter. Now below, there is a service manual, here at the back, is a factory troubleshooting chart that will be beneficial to you.
www.xantrex.biz/...Inverters/.../XS400_Owner_Guide(975-0054-01-01_Rev- B).pdf
The Biggest problems with Inverters is Flat/Low/Bad batteries, Sometimes it pays to remove the batteries and charge then up remotely, and then replace them, fully charged, Now a fully charged 12 volt battery should have 13.8 V DC at the terminals with NO LOAD. If the battery only reads 12 V it is not properly charged.
Dec 20, 2010 | Xantrex Technology Xantrex RS2000 Sine...
Temp gage in cluster shows the temp cold all the time. 2008 ford focus se. Dealer just replaced the thermostat, didn';t solve problem.
change your dealership ,infact i would say this is not a ford reconised dealer ship,it might advertise ford full stop.Any good dealer would reconise this problem as the switch and i have taught 16/17 year old who would have had your problem fixed and sorted in 10 mins.adrian,,,,,,,,,,,
Aug 21, 2010 | 2008 Ford Focus SE Sedan
I need a replacement comm board for a Xantrex Freedom Marine 25-12 Inverter/Charger. The battery temp sensor got shorted out and probably caused damage to the installed comm board.
I have the same unit that the charging function just died on. If I can't fix it and have to buy a new one, you can have my comm board for free. Should know my status in ~ a week .
Jul 03, 2010 | Xantrex Technology Heart Freedom 30...
Intermittent operation. Appears thermostat
No solution so far. But wanted to tell you that I'm having the same problem. I went through a lot of time, money and effort without success. Xantrex has abandoned me not responding to my e-mails anymore.
There could be a problem with the way it is (or not) grounded. I'm still experimenting.
I'm using a cheap $39.00 westmarine as a replacement. A bit noisy but so far much more reliable!
Richard
Jul 24, 2009 | Xantrex Technology RS400 Sine Wave...
Heart inverter had over temp led on
the temp control sensor is optional. If not connected the charger will charge at its default charge. No problem
Jul 20, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology RS3000 Sine Wave Inverter / Charger Logo
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
