How do i do half load or is it automatic for the weight of clothes
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
It depends on the machine, but most have some form of knob or button that adjusts the water level, though some of the newer machines will do it automatically.
Posted on Jan 01, 2013
I have a semi automatic Washing machine electrolux fabriguard turbo.the spin motor of machine rpm get too much slow in load while without load it runs fine.what is the problem behind this.
Probably you overloaded this machine and with to much load in it it Will run slower and probably shaking pretty heavy, try-out a little, but you also can look up the heaviest possible weight to load in this type of machine but more then five or six kilogram dry clothing is pretty heavy when wet..
Aug 19, 2015 | Electrolux Washing Machines
Spin with loud noise and shaking
The clothes inside the washing machine are not balanced. Too much weight on one side. Try to move some clothes to the other side to balance the weight. It may take more than one time of moving clothes to get it balanced correctly.
Aug 01, 2015 | Samsung WA400PJHDWR Top Load Washers
Depends on whether your machine has this function as newer machines are more economical in their use of water they already don't use as much as old machines used to so it may not be a function on yours.
Jan 01, 2013 | Washing Machines
Our LG227HW washer is showing an error code UE, what does this mean and how do we correct it
UE means an unbalance load. Either you have too small a load, too much of a load or you're washing a large bedsheet all by itself. If you are washing a large bed sheet or bed spread, you need to add about 4 bath towels in the load to help offset the balance problem. As for loads, you can only put in 15 lbs of dry weight laundry in the wash. Preferably, fill the tub with clothes half way up the window and no more.
Jun 29, 2011 | Washing Machines
I think the moisture sensor is bad in my kenmore he4 electric dryer. It works well on timed dry but does not stay on when using the automatic settings. It is still heating fine, it just stops prematurely...
it is a problem with how you are loading the unit. you must use the same type and weight of clothes or the sensor will think the light items are dry and then shut the unit off.
try to do a load of all towels and see what happens on the automatic cycle. if it does well then you just need to sort your clothes better.
the sensor is just 2 metal strips and will never fail.
Mar 13, 2010 | Kenmore Elite HE4 Electric Dryer
How much weight will the top of a top loader kenmore elite washer hold
Why would you want to know this, because if you put something on top of the washing machine, you won't be able to add or remove clothes.
That being said, depending on how the weight is applied (is the weight concentrated point load or is it a spread load). As a spread load, several hundred pounds, as a point load less than 100.
This does not consider applying weight to the head.
Dec 16, 2009 | Kenmore Washing Machines
I need an instruction manual for an Omega WD 1052 washer, please
I have searched everywhere as well, and no luck. I did find a bit of information on it which I have pasted below -- it might help a bit if you want to play around with it.
I would also suggest reading manuals from other wash/dryer machines to get an idea how they work--then maybe you can figure yours out by just pushing the different buttons and seeing what the display says. (At the end of this post, I have pasted a link to a different Omega washer/dryer -- perhaps you could skim it and see if it is at all similar to yours.)
Information About the Omega WD1052.2 washer dryer
THIRTEEN PROGRAMME:
The WD1052.2 is sequentially segmented into thirteen rotary positions for both easy and logical programme selection and for the quick identification of programme progression.
Choose from one of three wash sequences:
Programmes one through five are for the heavily soiled, more colour fast fabrics and daily wear.
Programmes six through to ten look after the slightly soiled, synthetics and for delicate items.
Woollens are exclusively washed on programmes eleven through to twelve.
CONDENSER DRYING:
The WD1052.2 can automatically dry a half a load of washing at the end of the wash programme provided the half load button is selected and a drying time is set on the centre control dial.
At any time the WD1052.2 can be regarded as an independent dryer, that is, a wash programme does not have to proceed into the drying stage. An example would be drying damp clothing or toweling from the bathroom. Simply choose a STOP position after either 5 or 10 on the programme dial. On the centre dial choose either full heat, the pink zone, or half heat, the green zone.
Another useful variation of the WD1052.2 is the ability to choose final spin only followed automatically by condenser drying. Having completed a hand wash, for instance, simply load the clothing and select final spin, 5 or 10 with the half load button selected and drying time set.
Whenever the WD1052.2 is in the drying mode the load can be easily accessed at any time via the porthole. The drying will automatically resume once the door is reshut.
Specifications:
Freestanding or Built-in
5kg (11lb) dry weight Capacity
2.5kg (5 1/2 lb ) dry weight condenser
13 Programmes
40 minute Fast Wash
Special universal 2B programme
Dedicated woollens cycle
Independent wash temperature control
1000 or 500 r.p.m spin speeds
Half load Economy selections
Drip dry no spin programming
Anti crease hold in final rinse Selection
Extra rinse option
Two drying heat settings
Stainless steel inner and outer wash drums
Two minute delay safety door release
Built-in heating element
Front mounted easy access lint/forgin matter
inspection
Automatic balancing of wash load
LINK TO A DIFFERENT MODEL:
http://www.omegaappliances.com.au/Documents/Document_205.pdf
Good Luck--I hope you get it working!
P.S. If you find this information useful, please remember to rate me! Thanks!
Mar 18, 2009 | Washing Machines
Squeaking due to weight of clothing
When you need this kind of noise and there is no abnormal vibration, then it depends on the drive pulley that pull the belt.
If it depends on the weight, and you get vibration it can also depend on bad dumper pads.
Here you can locate dumper pads and drive pulley below the tub.
Both parts are serviceable, repair should not be expensive.
If you need to contact a repair service, you can use the number listed on the owner manual.
Sep 05, 2008 | Hotpoint NWSR483EBWW Electric Dryer
Spins with little weight
Blown transmission seal. Get help for this.
Dec 22, 2007 | Kenmore 24432 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
