I cant get my ink tanks to "click" into place -help
I have been trying but the tanks tanks wont click into place - please help
  • 7,627 Answers
The cartridges , if the EXACT same Make, Model, made by the Printer Manufacturer, should fit properly. Get a light to see what the problem is , do not force. Look over the replacing instructions a second time. You didn't mention the printer Make, Model.
Posted on Jan 01, 2013
2 Suggested Answers
SOURCE: cant get ip4600 to work with new ink tanks having moved the chip
could not get anything to work so i had to buy new and original tanks with chips that solved the problem
Posted on Jun 01, 2009
B200 wont go on line or connect took off cord and still wont work
Error B200 means that there's a problem concerning the Printhead in most cases... in a great 90% of the cases is not fixable but...
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Gently clean the printhead contacts with alcohol.
6. Place the print head back in and lock the lever down.
7. Place all of the ink tanks back in the printer.
8. Close the cover and turn the printer off.
9. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
10. Plug the power back in and turn the printer on.
Jan 02, 2016 | Cannon Office Equipment & Supplies
What is error code -41
There doesn't appear to be any reliable information about an error 41 code for Canon inkjet machines. In a Brother machine it means a knackered printhead, but Canon has a different code for that. I can only suggest sending a message to Canon's web site/help desk to see if they can shed light on it.
Feb 12, 2015 | Canon Pixma MG5220 InkJet Printer
I need to change the black ink cartridge in my Canon Pixma iP90 printer, can you help me
Raise the printhead cover.
The printhead carrier will move to the center.
Remove the cartridge
(1) Push the tab.
(2) Remove the ink tank.
Then lift it from its slot.
Do not touch the Lock Lever; remove only the ink tank.
Unpack a new ink tank and remove the orange Protective Cap
(1) Insert a new ink tank with it slightly slanted.
(2) Push down on the "PUSH" on the ink tank until it clicks into place.
Close the print head cover and the carrier will move to the right.
Reset the print counter.
Instructions can be downloaded from:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip90#BrochuresAndManuals
Please rate this solution. Thanks
Nov 05, 2010 | Canon Office Equipment & Supplies
New black cartridge installed. Won't print. HELP please.
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Apr 04, 2009 | Office Equipment & Supplies
Cant get ip4600 to work with new ink tanks having moved the chip
Mar 22, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
How do I remove and install new black ink cartridge in Canon K10222 printer please
How to Remove the black ink tank on the Canon K10222
Turn the printer on and open the printer cover. (The print head will move from the right to the center.)
Lift up on the Push mark on the black ink tank to unlock the ink tank from the allocated slot of the print head and lift it out.
How to Reinstall the new black ink tank
Install the new black ink tank by inserting the the new black ink tank where the old one was removed. Put the back rear edge in first. Then press down the Push mark on the front top of the black ink tank until it snaps into place with a click sound
Close the printer cover and you are done
Hope that makes sense...
Take Care,
Michael
Nov 06, 2008 | Office Equipment & Supplies
Loading ink jets
Go here. Type "replace ink" in the Search window in the center of the screen and click on the Search button. Select "How do I replace or insert an ink tank?", then go to the section for installing the ink tanks.
Jun 12, 2008 | Canon PIXMA MP530 All-In-One InkJet...
IP4200 duplicate ink tanks.
Hello there scubadave,
I've gotten in touch with Canon and have somethinga little different to try. At the very least the error should change.(Sorry, gallows humor). Please read this entire response before takingaction.
After the upcoming test procedure, I have included alink and procedure to contact Canon tech support. The assure me theywill replace any faulty tanks.
The purpose of this exercise iseither rule out ink tanks that are behaving or isolate the one(s)responsible for the dupliucate error. You should write down the results of thistest. Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3.Confirm whether the printer recognizes the installed tank properly. Ifit does, it will indicate it does not detect the other ink tanks, asthey are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5.If the printer at any time indicates two of the same ink tanks areinstalled, the cause will be the last tank installed. For example, ifyou inserted an ink tank earlier, and you later inserted another inktank, and it said two of the same inks were installed, the cause of theissue is the last ink tank.
Click here for the Canon PIXMA iP4200 support page
Then click on e-mail support.
Fill out the form.
Under description, supply the following info:
Error- Duplicate Ink tank problem on my Canon PIXMA iP4200
<Describe how error occurs>
I have replaced the <color in> question> tank, reseated it, yet the error continues.
Youwill also need to list what inks are being used in the printer. Statethe type of ink that is being used and the order that the tanks areinstalled in the print head.
Provide the exact part number (such as BCI-6C, BCI3eBk, etc.) if possible.
The Canon support rep assured me they will be glad to replace the malfunctioning tank(s) for you at no cost. Please
respond with the test results, and specify the ink tank(s) that were not recognized correctly.
They responded quickly, professionally and apologetically. They want to help get this resolved for you.
I hope this helps end the frustration you must be feeling. If you need additional help or clarification, click the ASK button.
Remember: Good things happen to those who Rate.
Mike
Aug 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Ink tanks not lit but not empty
Hello there,
I've gotten in touch with Canon and have something a little different to try. At the very least the error should change. (Sorry, gallows humor). Please read this entire response before taking action.
After the upcoming test procedure, I have included a link and procedure to contact Canon tech support. The assure me they will replace any faulty tanks.
The purpose of this exercise is either rule out ink tanks that are behaving or isolate the one(s) responsible for the 1414. You should write down the results of this test. Please perform the following:
3. Confirm whether the printer recognizes the installed tank properly. If it does, it will indicate it does not detect the other ink tanks, as they are not currently installed in the printer.
5. If the printer at any time indicates two of the same ink tanks are installed, the cause will be the last tank installed. For example, if you inserted an ink tank earlier, and you later inserted another ink tank, and it said two of the same inks were installed, the cause of the issue is the last ink tank.
Fill out the form.
Error 1414 Ink tank problem on my Canon PIXMA iP4200
The error won't go away.
I have replaced the <color in question> tank, reseated it, yet the error remains.
You will also need to list what inks are being used in the printer. State the type of ink that is being used and the order that the tanks are installed in the print head.
respond with the results, and specify the ink tank(s) that were not recognized correctly.
Mike
If you could take a moment and rate this response, I would appreciate it.
Apr 04, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
jasbo
jasbo
