Question about Dryers
Bosch AvantiXX WTV74307UK Vented Tumble Dryer
SOURCE: Bosch WTA 3100 Tumble Dryer ON/OFF switch
The on/off switch is combined with the door release switch in one item - part number 154145 (a little over £20) and my problem was the door interlock bit had failed. The following worked for me :
Plug out, remove top panel, and open door + look up at switch panel - you see 5 slots under the switch panel (the 2 outer ones are mostly covered by the main front panel). Start at either side and work across, using as wide-bladed a screwdriver as will fit across the slot width : put a wood block under blade as a support and lever bottom of panel towards front - each has a plastic pin behind pointing towards the rear, held by a spring clip. Each will pop clear and when all are unclipped you rotate the panel outwards from the bottom edge, taking the timer knob and its drive linkage with it. To get switch out I removed the door and the screws around the main front panel - one is hidden behind a cover plug below the access port (to gain access to bottom screws on main panel, lever the bottom panel outwards along its top edge).
Posted on Sep 08, 2008
  • 686 Answers
SOURCE: Does the Bosch Tumble Dryer WTA3003GB/01 have a trip reset button
YOUR DRYER HAS A FUSE AND NEEDS TO BE CHECKED. SEE IF IT IS LOCATED SOMEWHERE WHERE THE POWER CORD COMES IN AT. IT SHOULD BE CLOSE TO THE MAIN POWER COMING IN OR MAYBE EVEN IN THE CONTROL PANEL AREA.
Posted on Apr 10, 2009
  • 7 Answers
SOURCE: Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
SOURCE: Bosch Maxx WTL 6100 tumble dryer - door switch
i have wtl 6100 bosch and the mashine is not running. There is power on the machine, it can run but it can not run and heat. I can get light in al the panel, but it is like it needs to be rebouted. I can get it to show 111,222,333 etc in the window but i cant get it to work
Posted on Sep 05, 2010
SOURCE: water tank full (!) in bosch tumble dryer WTE86301gr
As a matter of fact I have solved the problem. The dryer is now fully functioning again. :-)
I'll try to explain how to fix the problem:
The water that condenses in the condensor (doh!) drips down into a container situated below the condensor. The moist air that passes through the condensor is the same air that circulates via the clothes, thus it also contains some lint that the filter doesn't catch. Over time there will be some build-up of lint and mucus (?), clogging the tank AND a sensor that sends a signal to the electronics to start the pump that evacuates the condensed water to the removable tank in the upper part of the machine. This messes up the function of the water evacuation system.
Alright, pull out the condensor and find a hatch in the 'floor' in the farther part of the compartment. Below the hatch you'll find the container that collects the condensed water. Start by cleaning it as thoroughly as you can. There are a few 'nooks and crannies', take your time, also flush with some fresh water and maybe some gentle cleanser to get rid of the mucus. The pump and the sensor for the pump are located in the left part (viewing from front of the machine) of the container. Try to flush there as well.
If this procedure doesn't solve the problem you'll have to disassemble the machine to also be able to remove the pump and sensor housing. I had to do this on mine. Quite a few screws to remove and keep track of, but pretty straight forward if aren't too uncomfortable with 'fixing things'.
I have some pictures of the 'project' somewhere, let me know if you would like to see them or if I may help you some other way.
BR /Hans
Posted on Aug 09, 2011
Bosch vented dryer stops after a few minutes with drying and crease hold/end lights flashing
It could be that it is over heating. I would check the vent tube to see if it's clogged or check the part where you hook up the vent to the dryer
Nov 26, 2015 | Bosch Dryers
Bosch tumble dryer
Try holding down the start button for 10 sec's to reset it.
Jan 15, 2014 | Dryers
Instructions manuals
go to www. retrevo.com or www.manualslib.com and download for free.
God bless you
Dec 10, 2013 | Kitchen Appliances - Others
I have a TB condensing tumble dryer, model TM310W, which has always worked well, but lately, although the clothes are drying, there doesn't seem to be much water going into the reservoir. I can't find it...
The first decision you must make when buying a tumble dryer is whether to buy a vented or a condenser dryer. As you'd expect, there are pros and cons for both. This page helps you understand all of the differences, including the reliability and repair implications. Condensor tumble dryers are becoming more popular but vented tumble dryers still have some advantages and the convenience of not needing a venting hose (as always) requires some compromises.
Until I can put together my own reviews the best Tumble Dryer reviews available online are by Which?
Due to their resources and independence, Which? usually have the latest reviews and collect the opinions and experiences of thousands of members - Which? tumble dryer reviews (Plenty of free information but will need to be a subscriber (take advantage of the 1 month trial offer to get the full benefit)
Vented tumble dryers are cheaper than condenser dryers, they are also simpler, more reliable and more economical to run. According to Which? "on average, vented tumble dryers use about a fifth less energy than condenser dryers to dry a full load of cottons."
So why bother with a condenser tumble dryer? Well condenser tumble dryers are a convenience product but they do offer a solution to a genuine problem for some where venting the dryer outside is difficult or even impossible.
My advice would be that if your tumble dryer can be sited somewhere that allows you to correctly vent it outside, either through a wall or through a window, then a vented dryer is probably best. If this would be particularly awkward, then buy a good quality condenser dryer, which should condense the steam into water.
Modern washing machines now have a far superior spin speed, and, of the ones we recommend, the cheaper model has a 1200 spin speed, the other a 1400 spin speed... so your washing will be fairly reasonable (some items could be about ready to iron) and this, in turn, could affect your other choices.
Could you get away with just airers and a washing line? Or have you considered a dehumidifier?
A Spin Dryer... will work efficiently, and is cheap. The main advantage to it is that it is only the size of a large pedal bin, so it can be stored under the worktop in a small amount of space.
A Tumble Dryer... much more expensive... for a decent quality item you need to pay a quite steep price. They do a good job, but are another full size kitchen appliance to find room for.
A Washer/Dryer... instead of a washing machine... disadvantages, if it goes wrong then you have no back up in either the washing or drying department... and of course being a more complicated piece of machinery, it IS more likely to break down! The only advantage is that it will be a space saving item.]
please comment on these on how helpful.
Dec 21, 2010 | Electrolux Dryers
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Apr 09, 2009 | Bosch Dryers
Tumble dryers
condenser takes the warm moist air and keep circulating it within the dryer ,,some times these unit have to be emptyed of water every so often..exhaust vent have to be vented directly to out side..
Sep 08, 2008 | Zanussi TC7114W Electric Dryer
Dryers Logo
81 people viewed this question
Top Dryers Experts
