Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Can i use kero klean fuel treatment in my reddy heater with diesel
shastalaker7
  • 1515 Answers
SOURCE: What will happen if I burn a diesel/ gas mix in a
Hi, If the heater recommends kerosene or diesel only, and you mix gas into the situation, you will get an explosion and fire loosing not only the heater but most everything else.Unless the spec's say you can since it will use other fuels, gas would be one I would not use, mixed or not, like I say only if it says you can. At 70,000 B.T.U.s, as it says above, this Reddy heater burns hot anyway, and I don't want to put you in a dangerous situation by saying yes, go right ahead? So please check first, I would say no way. Good Luck, and Sincerely, Shastalaker7
Posted on Nov 21, 2009
  • 188 Answers
SOURCE: REDDY HEATER 40,000 BTU KEROSENE&DIESEL
Clean your nozzel, check your fuel & air lines, you may need to replace Spark plug and filters. You can go to the manufacturers website at www.desatech.com and they offer service manuals. I hope this helps you!
Posted on Jan 28, 2010
  • 3 Answers
SOURCE: CAN I PUT DIESEL IN MY KERO REDDY HEATER 150,000
yes if it is NO#1 DIESEL
Posted on Jan 31, 2010
  • 224 Answers
SOURCE: where can i get ignighter
I would try Grainger or Reddyheat.com.
Posted on Dec 20, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: can i run diesel fuel
Sorry to read about your problem, I hope this helps you out.
yes you can with no problems
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Testimonial: "They are very helpful and quick to respond. Even on a Holiday. Thank you!"
Will diesel fuel substitute for number 1 heating oil. cant by that around here
Yes, you can burn diesel in there but... you will have more trouble with the heater... it burns crappy and soots everything up...actually the best thing to burn is K-1 Kero in them... that burns the cleanest... and it won't gel in really cold temps...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 08, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Can diesel fuel be used instead of kerosene?
Hello,Yes but it might be slightly smokey.I have used kero in place of diesel with good results.
Oct 30, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
CAN I PUT DIESEL IN MY KERO REDDY HEATER 150,000 BTU HEATER AND WILL IT SMELL OR RUIN IT
since the combustion temp of diesel is different from KERO, expect the heater to shut down from overheating at times.
since it will probably heat up faster than on KERO.
Jan 31, 2010 | Reddy R60A Utility Heater
Is it okay to burn Premium Diesel instead of Kero? Also, will I have a stronger odor problem with the premium instead of kero?
yes its ok, just make sure the air pressure pump is dialed in right. With the right air pressure the heater will perform at its best and burn as clean as it can. Its the slotted set screw (plastic usually) on the back next to the air filter. Turn it in 1/4 turn at a time till the nose cone is almost all red or orange in color. This will give you the cleanest burn. Then adjust doors/windows for fresh air as needed. Hope this helps
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Does not light sometimes smell kero and have to reset and then it will work
Sounds like the optical EYE is dirty. It sits right below the fuel nozzel. remove it clean it and reinstall it. 50 cents says it will light, prividing you have spark and fuel.
Jan 01, 2010 | Reddy Heater R70 Portable Forced Air Space...
Where can I get a pressure gauge to adjust the kero heater pressure ..... the kero odor is bad
go to mcmaster-carr industrial supply. the air pressure should be around 3-5 psi on that heater.
Oct 12, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
Types of fuels
YOU COULD RUN ON # 2 HEATING OIL BUT WOULD NOT RECOMMEND DIRTY AND MORE LIKELY TO GUM ALSO DOES NOT GENERATE SAME BTU PER GAL I WOULD STICK WITH KERO
Jan 16, 2009 | Reddy Heater-30-55,000 BTU Variable
Heater won't start properly
Remove the nozzle from heater and clean, be carefull around the ignitor.
Dec 31, 2008 | Desa International Reddy Heater R40 40,000...
Diesel
well, somebody once told me that if you add a quart of oil to 5 gal of kero, it makes a good diesel substitute. So, in theory, I would add a little ethinal (corn gas) to the kero.
Feb 20, 2008 | Corona 23-DK Compact Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
