Question about GoVideo DV2140 DVD Player/VCR
Problems hooking it to the television
With a new tv we can't get the dvd player to work. How do you hook it up
  • 11,896 Answers
The colored jacks match up to the jacks on tv. Tv must be turned to AV channel, Or input channel. The ports they are plugged into should have a channel printed by them.
If you are hooking it up through a VCR it is the same. Whatever it is hooked up to has to be on the right channel.
Channels are usually: AV or Input
Posted on Jan 18, 2009
2 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
My new tv suddenly clicks off and goes totally green.this is new sony lcd and other lcd did this also so must be my sat equipment, yes
Please hook DVD player with TV and check TV still gives same green screen problem with dvd playback?
If TV works fine then satellite box sounds bad and need to be confirmed by hooking it with another TV.
Dec 06, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hook up new dvd player
you need to tell the t.v. via the remote which input it is supposed to be looking at in the uk the button to press is usually called av, press this and it will go av1 av2,etc look on the back of t.v. to see which one you are plugged into and this should cure it please leave feedback thanks
Jul 20, 2009 | TruTech PM1919BXA1 19 in. LCD TV
How to hook up my dvd
I'm assuming you have your video 1 hooked up for your cable. I would use video 2 for you dvd player. Use the rca connections, yellow, red, white. plug it into the video 2 slot on your tv and hook the other end on your dvd player. you will have to change your input on your tv to video 2 to have your dvd player work.
Apr 05, 2009 | Samsung LN40A550 LCD TV
Have direct TV, need to hook up sanyo tv to a panasonic DVD.
leave direct tv cables where they are, and hook up dvd player directly to tv (do not hook up dvd player to direct tv box, it will not work)
Mar 15, 2009 | Sanyo Televison & Video
DVD Hook up-Olevia 266-T11
From Cable Or Rca Out Of Your Dvd Player To Your T.v. Make Sure You Push The Tv/Video Button To View The Dvd If Its Hooked Into The Rca Jacks.
Jan 14, 2009 | Olevia LT32HVM 32 in. LCD Television
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
Dvd hook up
how do i hook up my dvd player to my proscan tv
Apr 12, 2008 | Proscan 26LA30Q 26 in. LCD Television
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
GoVideo DV2140 DVD Player/VCR Logo
101 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
