My color ink cartridge needs to be replaced. I can't go to the store right now so I was printing a document in black and white but the printer won't print anything while my color cartridge is empty. Can I override this?
    Genius:
  • 2,120 Answers
No.
Posted on Jan 18, 2009
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I rwplaced the black ink cartridge a week ago. Now the printer says the colored ink carftridge is emty aand it will not let me print. I only want to print black and white and not able to get to a store...
The only way to solve the problem is by replacing the color cartridge.
If you only want to print black and white get a black and white printer.
Sorry, but that's the cold hard facts.
Apr 09, 2011 | Office Equipment & Supplies
I have an Canon Pixma Mp 496 can i know how much documents can i print with it in fast mode. and also the capacity of those two cartridges
Well, here's what Canon says. In my experience, you can expect to go through a black cartridge in about 500 sheets of paper, less for the color. Our Canon uses ink quickly. The printing speed is pretty fast for a printerthat is for black-and-white documents around 8.4 ipm and a color document printspeed of about 4.8 ipm. While for 4R size photo print takes about 43 seconds.Canon PIXMA MP496 resolution of 4800 x 1200 dpi for (max). It is said the all-in-one, because already integrated between print, scan and copy. For copies, this printer has a speed of around 7.6 cpm for black and white documents, while for the color is obtained at about 2.6 cpm.
Oct 22, 2010 | Office Equipment & Supplies
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
Printer won't use the black ink cartridge.
when you print black document the printer should only withdraw black ink,or you have go back to computer to tellthem print black and white, How? when you click print the screen will show out printer setting box ,you can find the option over there.
Dec 09, 2008 | Lexmark X2600 InkJet Printer
When I print, only the color cartridge is used. I'm printing documents that are all black and white. How do I print with the black cartridge? I have a full black cartridge, but my printer won't let me...
if your document only black and white , the machine only use black ink, no going withdraw the color ink. but you have had to leaved the full color ink in the machine.
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
555 people viewed this question
jasbo
jasbo
