I try to start the machine an i get error 133 i have a pacemaster broze basic
  • Computers & ... Master
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Posted on Jan 01, 2013
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
Pressed express incline then machine went to top incline and received error 306. What is the problem?
Err 306 - Indicates power supply problem at start up.
1. Check all wiring for proper connections and damage
2. Replace the lower power supply board.
3. Replace the drive motor.
Recommended Parts: lower power supply board, wire harness.
I would suggest you get a tech out first. 877-805-1030
Dec 24, 2013 | PaceMaster Silver Select XP Treadmill
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Treadmill will not start up error comes up in window
please LUBE the deck belt with silicone or was see the owner manuals and proceed according. However if after you did lube the problem remain, is TIME to replace the old deck board.
God bless you
May 27, 2013 | PaceMaster Bronze Basic Treadmill
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
Error message 133
It is an error code that refers to a black cable that attaches to the main circuit board located by the motor. It looks like a fat telephone wire. Unplug it and reinsert at both ends but try the bottom one first as it is easier to get to. If doing this does not work you can meter the pins on the cable to make sure that there is not a problem with it or you can replace it. If the cable is good and you continue to get that error then you will have to replace the power circuit board. I hope this isn't the case because they cost around $450.
Jan 25, 2013 | PaceMaster Premiere EXT Treadmill
Bronze Basic Treadmill Your question about Bronze Basic Treadmill has been posted. i have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks solli...
yes there are some reset button see your owner manual and do it. if you do not have owner manual download for free
LUBE the deck belt and rollers bearing inmediately.
www.fitness.manualsonline.com
Happy New Year. God bless you
Jan 02, 2013 | PaceMaster Bronze Basic Treadmill
I have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks solli On 2013-01-01, at 1:32 AM, FixYa.com wrote:
RESET the machine and try again.
However if you can get again the code, Lube the deck belt and rollers bearing very well.
Test the motor and controller motor see the block diagram
see the video and proceed according.
Jan 01, 2013 | PaceMaster Bronze Basic Treadmill
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Computers & Internet Logo
241 people viewed this question
David Payne
David Payne
