Question about Reebok Exercise & Fitness
My reebok Z8 treadmill shows that i burnt less calories than i have.
After walking at a speed of 3mph for 20 mins, my treadmill says that i only burnt 5 calories? Is there anyway to troubleshoot it?
SOURCE: I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Posted on May 18, 2009
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
  • 6 Answers
SOURCE: After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Posted on Jul 29, 2009
buffalonyman
  • 1865 Answers
SOURCE: Pro-form 320x treadmill slows down then motor stops.
Sounds like it is overheating, you have to disassemble the unit and find why it might be overheating
Posted on Aug 29, 2009
maxtreadmill
  • 832 Answers
SOURCE: Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Posted on May 24, 2010
What is fault code E03 on Raebok Z8 Run treadmill
E03: This indicates a fault with the mounted speed sensor on the drive motor. Contact technical support.
Official Reebok Fitness
Mar 02, 2017 | Exercise & Fitness
Error code E-02 on a reebok z8 treadmill
Hi. Have error code e2 on reebok z8 can you advise what this is.
Thank you.
May 31, 2014 | Reebok Exercise & Fitness
Reebok z8 error E03
I can not adjust my tension on my machine
Feb 27, 2014 | Exercise & Fitness
My Reebok Z8 Treadmill says 'E-02' on the display screen. It is constantly beeping and fails to work, How can I fix this?
Run the software calibration for easy diagnostic, and fix it. The speed sensor, can be dirty or faulty, test with s.calibration. see the diagram attached.Read you owner manual or go HOOD cover motor and follow the instruction.
Oct 23, 2013 | Exercise & Fitness
Z8 reset
1)adjust the reed switch, clean , and tight the wires connector very welll, see the diagrams
2) Tight the ribbon cables, from keypads. tight the display board vs lower board.
3= Try again and proof.
God bless you
Jun 14, 2012 | Reebok Exercise & Fitness
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Nov 03, 2011 | Exercise & Fitness
    Reebok treadmill Z8 error E-01
    Dear Sir:
    Thank you by your request, I will help you inmediately.
    ERR 1 - Motor Movement
    ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
    from the speed setting.
    Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
    the signal is not reaching the display.
    Thank you in advance, sincerely. God bless you
    If you need further assistance, contact me
    E.CUADRA
    MANAGUA, NICARAGUA. C.A
    Sep 28, 2011 | Exercise & Fitness
    How do I oil my Reebok i-run treadmill?
    I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
    Mar 07, 2010 | Reebok Exercise & Fitness
    Reebok RX100 won't work right
    Sounds like you could possibly have a bad drive motor or something is wedged into the walk belt somewhere keeping it from turning. Check this out. One more question. How long does the walk belt turn for, seconds, before it stops. Is it like 3 to 5 seconds or less than that.
    Jun 29, 2009 | Reebok Rt1000 Treadmill Walking Belt
    Exercise & Fitness Logo
    41 people viewed this question
    Top Reebok Exercise & Fitness Experts
    Electro Med Services...
    Matt Olenzek
    Matt Olenzek
    Shehu Pro
    Shehu Pro
    Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
