Question about Dayton Gas Furnace Heater
My light on circuit board flashes four times
Chert sayshigh aux or spill limit switch
  • Dayton Master
  • 2,597 Answers
Jump out limit switch and see if it works and stops flashing .
Posted on Jan 01, 2013
Ever limit switch i changed in my Weatherking furnace, it breaks the switch, what could cause this?
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
Jan 02, 2016 | FACTORY AC PARTS Limit Switch Double Pole...
Four flashes open high limit explain
Blower is probably bad. Dirty filter or not enough air flow
Nov 17, 2012 | Emerson Furnace Control Board Lh33wp001...
GMP125-5 four flashes replaced high limit and board. when powered up the blower comes on even with the T-SAT in off position.still getting four flashes from new board
when a high limit opens it tells the board that there is to much heat. The board shuts down the gas valve and turns on the blower. Find the limit that is open, sometimes you can reset them but most of the time you replace it. When you either change it or reset it, after power down then up, it should go back to normal.
Oct 06, 2011 | Goodman GMS90703BXA Heater
The fan in the heater turns on but the heater does not turn on.
Probably a bad circuit board. I have the same problem once the water gets above about 82 deg. I tried cleaning the filter and strainer, cleaning out the heat exchanger, replacing the temperature limit switches, bypassing the pressure switch, and cleaning the ashes off the burner, and none of these worked.
Jul 30, 2010 | Pentair Minimax NT Heater
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
Furnace main fan comes on but the furnace doesn't come on. The indicator red light blinks four times. What does this signify?
You have to get in to the main circuit board. At the bottom of the circuit board it will tell you what the flashes mean, in very small print. Read this print for you codes.
Dec 25, 2009 | Goodman GMS90703BXA Heater
I have a GPG13 unit that is locking out on the aux limit switch. Can I increase the post timer for the bnlower. The blower compartment stays too hot after shut down and causes the aux limit to shut off.
You should be able to adjust the Blower off time by way of Dip switches on the circuit board...these are typically and band of tiny switches on a red block . Is the furnace new??? You may also increase the speed of the blower by using "High" speed which is the same as the AC speed...heat typically uses Medium...also make sure your filter is Clean and yoiur retun air vents are open and not obstructed
Oct 25, 2009 | Heating & Cooling
Circuit board blinks four times
check your filter if thats clogged that will send a four flash limit open or your blower motor might be bad these units are known to have popped rings and cracks on thier heat exchangers if there isnt enough airflow if your filter is clogged or motor is shot i would call someone monday and get your heat exchanger inspected
Mar 11, 2009 | Goodman GMS90703BXA Heater
Dayton Gas Furnace Heater Logo
208 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
