Mine spins but there is still water in clothes when I take them from washer
  • Washing Mach... Master
  • 17,129 Answers
Possible that the drain pump is not pumping out the water, Also if the spin speed is low there will be water accumulating with the clothes.
check the spin speed, check the belt , check the spindle to see if this is jammed.
finally clean the drain and pump check this link: drain filter
Posted on Jan 01, 2013
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
  • 7 Answers
SOURCE: washer not spinning the clothes completely
For the the initial filling of the tub, the pump is not involved. The rinse cycle is also done with fresh water supplied by the inlet valve, although the water pump may be running simultaneously to remove the water while it is being added. Try removing front (or top) cover and find the water pump. It will have connecting hoses clamped to it. Check the hoses for blockages first. Then check the pump for any objects inside or broken impeller blades. If impeller is broken, replace it only if possible --- if not, you'll need to purchase a new pump. Hope this helped.
Posted on Dec 22, 2007
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
SearsTechToo
  • 261 Answers
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Posted on Oct 16, 2008
asish_shrm
  • 121 Answers
SOURCE: Kenmore 90 Series Washer
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Posted on Nov 12, 2008
I cannot find my pump filter on my front loader washer.
mine is front right hand side underneath the washing machine
Feb 12, 2012 | Frigidaire Washing Machines
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
My Frigidaire Front load washer will not spin during its cycle, we were able to unlock the door and remove the very wet clothes, the washer will fill with water and the pump will pump out the excess water...
just had this happen 3 days ago w/the same machine (bought mine in 1999). Repair man said the motherboard is shot. >$300 to repair, so I am looking for a new machine....good luck. jbitker
Jan 21, 2011 | Frigidaire ATF6000ES Front Load Washer
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
My bosch front loading washer on the small cycles will not spin the water out of the clothes..why?
Does it sound like the machine is spinning as fast as on longer cycles?Some machines run a slower spin speed on small cycles which can leave clothes wetter than normal. I've got this on mine and all I do is when the wash has finished I change over to the fast spin only program which then takes it to it's highest spin speed.
Jan 25, 2010 | Bosch Washing Machines
Spin cycle does not take all the water out
Check the coupling between the motor and gear housings. It should be a rubber piece sandwiched by plastic piece. It could be broke. Just happened to mine. That prevents the maichine from spinning the cloths dry.
Mar 01, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washing machiene not spin dying
Most likely the coupling near the motor. go to fixitnow and search your washer problem. Tells how to fix it, I'm doing mine now.
Feb 23, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Washer won't spin dry clothes
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
