Question about Sony KP-46WT510 46" Rear Projection HDTV
RGB lamps are not aligned
Daughter was watching a 3D movie, left it running and the movie went back to the Menu screen when it was finished and it was left like that for 5 or 6 hours. now RGB lamps are like i need the 3D glasses on to watch it!! No alignment, and the screen area itself has gone convex instead of rectangular. Tried the Flash Focus to no avail and no sure how to run the Convergence function. The TV has been unplugged for more than 1/2 hour now as per instructions from where i bought said TV as they are hoping it will reset itself automatically.
anyone out there with the remedy i require???
jim
  • Sony Master
  • 3,459 Answers
RGB lamps are not aligned - 2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Posted on Feb 13, 2009
One Blue line is on the screen
open up the projector and you will see a small screen attached to the lamp and a Flex Cable attached to the screen,
Remove the cable and Clean it with Alcohol Liquid from both sides then put it back and check.
Aug 02, 2015 | Epson PowerLite Home Cinema 3020 LCD...
I'm trying to watch a 3d movie in my blue ray 3d
First off is your TV a 3D TV. If it is you should be able to go into the menu setting (or on the remote) and change the display from regular TV to 3D. Then your 3D blu-ray player should recognize it.
Jul 15, 2017 | Televison & Video
I have mitsubishi vs-50800 i was watching a movie and the screen just all of a sudden went blury and the color is all mixed up i went to the convergence menu and it wont allow me to move the colors left or...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 03, 2011 | Mitsubishi VS-50800 50" Rear Projection...
HI I HAVE A 73 INCH 3D TV I BOUGHT A FEW MONTHS AGO-- ORDERED A 3D MOVIE CHRISTMAS CAROL-- INVESTED IN A BLUE RAY THREE D PLAYER-- AND I AM UNABLE TO WATCH ANYTHING IN 3D I FEEL I KEEP SPENDING...
3D in tv technology wright now are in it infincy.Not worth the money to buy the 3D LED tv and it 3D external devices.Right now are very limited in productions in movies in 3D world or 3D movies for tv or transfer from 3D movies from the movies theather Big Screen.Right now,just best to watch 3D movies in the theather Big Screen.Stick to a 2 dementional LCD tv screen for at lest another 5 years,before there are 3D tvs and movies,will make a difference in ur lives.
Dec 04, 2010 | Televison & Video
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Need to activate dvdxcopy gold
this software in my own experience is not very user friendly. I recommend getting on a torrent site and trying different DVD software instead actually. Unless you purchased a key, then click on help, and there you should be able to enter your key code to activate in the 'About' section or Register.
Oct 20, 2009 | 321studios DVD X Copy Gold (200095) for PC
My rca 52'' flat screen tv
It sounds like your TV needs to be aligned. There should be a menu item in your setup menu called "Alignment". Once you choose this the system will either automatically align itself, or the screen will display a graphic that will allow you to align the guns manually. Normally you will move either up or down or side to side until 2 separate lines look like one.
Jul 14, 2009 | Televison & Video
Lost picture all color lines are at top of screen
Thats what happened your convergence went out, those parts can be found online for as little as 12.50 a piece. If you are good with solder its an easy fix. I found a guy on craigslist in denver who fixed it for 150
good luck
Feb 11, 2009 | Samsung PCN5425R 54" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
107 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
