Question about Magnavox Televison & Video
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
Model #: ZV427MG9
  • Magnavox Master
  • 5,341 Answers
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Posted on Jan 01, 2013
SOURCE: I have a Magnavox ZV427MG9 A VHS & DVD Recorder
Ensure that your source is correct. L1 is the rear inputs and L2 is the front inputs. If you have it set to L2 then you have no information from the TV getting to the recorder.
Posted on Sep 23, 2009
SOURCE: I just bought the zv427mg9
the magnavox ZV427MG9 vhs to disc dub recording can not
be paused. you can not pause and start dub recording in this
mode. you must let it run start to finish . It also states this
in the manual which disspointing....
For this type of recorder it should be able
to do just that, pause while dub recording whs to disc, but it
doesn't.....
Posted on Jan 27, 2011
  • 8457 Answers
SOURCE: I have a Magnavox Digital Video Disc Recorder
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Posted on Mar 16, 2011
Demonic-2011
  • 508 Answers
SOURCE: I have a Magnavox DVD
You can probably download the pdf of the manual for this model from the following site:
http://tv.manualsonline.com/manuals/mfg/magnavox/zv427mg9.html
The document should feature a picture of the unit. This is for the ZV427MG9 model ONLY.
I hope this helps somewhat.
SOURCE: ZV427MG9 A It will not record when recording from
same as above,check the mode swith.i's stuck in the dvd posision,you need it in the vcr mode to do that proceedure.
Posted on Oct 29, 2011
My Magnavox Digital Disc Recorder & Video Cassette Recorder will not play DVD-RW discs. How can I solve this problem or get a replacement unit.
It claims to play -RWs finalized in DVD-VIDEO format, not VR. If a disc is recorded/finalized on a different recorder, not all players can play it. This is the price we pay for the convenience of the digital system.
Feb 11, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
Can't view recorded DVD
if the movie you recorded ? was copy protected. then your dvd prob did not record
Nov 22, 2012 | Magnavox ZV427MG9 DVD Recorder/ VCR
Recrod vhs to DVD dubbing
Unfortuneately a lot of products are not consumer friendly leaving people confused about what to do.
Mar 04, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I have a Magnavox DVD Recorder/VCR ZV427MG9, but I don't have an instruction manual to go with it, at least on how to record from VHS to a DVD, could you tell me where, via internet I would be able to get...
Mar 15, 2011 | Philips DVDR90 DVD Recorder / VCR Combo
I just bought the zv427mg9 a and I can not get it to pause recording when recording from vhs to dvd. Can you help?
doesn't.....
Aug 22, 2010 | Philips Magnavox DVD+R/+RW Recorder/VCR
Interface SA-DX940 with Sony Vega TV and Magnavox Video Recorder
you need an upscaler for the vision sound will be dolby stereo 2
Dec 08, 2008 | Technics SA-DX940
Televison & Video Logo
101 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
