Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
Kitchenaid KUDE60 FVWHO clean light is flashing code 6-1
The clip holding the hose from wash motor went off and had a water spill. I replace the hose with new clamp and now it does not start and the clean light is flashing 6-1
aborcass
  • 2651 Answers
SOURCE: Lights flashing on clean. Program does not take.
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Posted on Jan 10, 2009
  • 188 Answers
SOURCE: clean light flashes cant get to start a wash cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It's not as common but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 07, 2009
SOURCE: Kitchenaid KUDP01 not cleaning dishes
is there a filter in the dishwasher that needs to be changed out?
Posted on Jul 09, 2009
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
  • 1382 Answers
SOURCE: Kitchenaid KUDS01FL -Dishwasher -
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Posted on May 20, 2010
Testimonial: "SOLVED THE PROBLEM"
The machine starts then stops a few minutes into cycle and the code "F" flashes then "H" flashes? What is the problem? DW 7/31/11
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Aug 01, 2011 | KitchenAid KHWS02R Front Load Washer
KAWS750L Washer; motor runs, no drive to transmission. Have the sides off and looking at motor assembly at bottom. How do you access the broken part between motor and transmission?
That's the drive coupling that is broke you will have to remove the 2 clips that hold the water pump on that has the 2 black hoses going to it then slide the pump straight off the motor shaft. Next you will need to remove the 2 screws going onto the two other clips holding the motor to the transmission then remove the 2 clips and the motor will come off replace the drive coupling with a new one might need a socket and hammer to put new drive coupling ends on make center metal bearing even with motor shat and shaft coming out if the transmission and put the rubber boot on the transmission and replace the motor and clips same order as taking it off hope this helps and good luck.
Jan 06, 2011 | KitchenAid KAWS750L Top Load Washer
Fast flashing
The outlet pump could be triggered because the "anti flood device" polystireen float and micro switch at the base of the washer has detected a water leak from a leaky hose or water spil) This device automatically puts the pump out motor on and stops any washing process.You need to dry the base of the washer and determine what caused the water spill. This should start the washing prosess.
Mar 20, 2010 | Dishwashers
Code nd on maytag neptune
You likely need the drain pump cleaned. Unplug and pull the washer out. Remove cover in back. The pump is attached to the washer's floor. Pinch off the hose from tub to pump. There's going to be some water left in the pump and drain hose, so get a large towel ready. Remove screws attaching black piece (motor) to white piece (housing), pull out motor and clean the housing and motor impeller. Wear gloves, as it's always a nasty stuff what comes out. ;) Reverse steps to assemble the pump back together. If you don't hear pump running after completing all the cleaning, you may need to check the wiring and/or replace main control board located inside the console. If the pump seems to be running but no water is being drained - replace pump. for Maytag MAH5500B the part number is 25001052.
Vlad
First Choice Appliance
Jan 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
After washing pillows in a GE washer it will not spin and water will not drain out Serial number WIRR417061WW
Unplug machine. Scoop out water. Remove front panel by pressing in on clips at the seam with the top, using a putty knife. Remove pump mounting screws and hoses from pump (you will spill some water) and clean out obsturctions. Reassemble and test. May need to be repeated.
Sep 05, 2009 | Washing Machines
Have water leaking out when washer is filling up. What could be the problem?
It sounds like you have a leaking pump. The pump is easy to replace:
1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
4 Remove the 2 clamps off of the hoses.
5 Install the new pump into the hoses, and reinstall the clamps.
6 With the retaining clips installed into the motor housing, install the pump.
7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
God Bless
Jul 08, 2009 | Whirlpool Washing Machines
Samsung B1245 front loader
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Mar 15, 2009 | Samsung B1245 Front Load Washer
Kenmore Heavy Duty 70 Series Model 110 water leak
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
Please rate this solution
Mar 16, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag MAV2755AWW Washing Machine is leaking water
Jan 11, 2008 | Maytag MAV2755A Top Load Washer
Water leaking from under the front of the washing machine
Dec 17, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
198 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
