Question about Bosch Ovens
Does bosch hbl 445 oven have a baking element ?
Kimi
  • 277 Answers
SOURCE: HBL 445
Bosch main support number in US: 1-877-267-2499 Email support: Click here
Posted on Nov 27, 2005
SOURCE: Faulty bake or broil element
You will need a T20 screwdriver (star shaped) to remove the back plate on the electric oven
Posted on Dec 29, 2006
  • 262 Answers
SOURCE: Bake element in smaller oven replacement
I always unplug oven or turn off power make sure though it will bite ya and hard after turning power off if you do it at the breaker turn stove top on make sure it don come on remember its 220volts and it hurts open oven door remove all racks.Then remove the screws mounting element to oven pull gently towards you (you may have to lift the front up a little) pull old element out until you see the spade connector (plug ins with the wires attached) remove these should be two of them be careful not to let wires go back into the cabinet put new element in hook wires back up to wires push back into the hole and put screws in turn power back on and test. this can also be done by taking the back off also and doing the same thing in the oven.hope this helps ya
good luck
Posted on Dec 08, 2007
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    Oven heats slowy
    Most often this would happen if one of the heating elements isn't working to pre-heat the oven.
    Nov 07, 2013 | Bosch HBL 445 Stainless Steel Electric...
    Tip
    Common heating faults with Bosch HBL 445 Stainless Steel single oven
    For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
    To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
    2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
    3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
    4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
    on Jan 19, 2010 | Bosch HBL 445 Stainless Steel Electric...
    Tip
    Common heating faults with Bosch HBL 442 / HBL 446 single oven
    on Jan 19, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
    Oven fan not working
    If you're referring to the fan in the rear for convection cooking (as opposed to the fan for cooling the electronics), it's replaceable by removing the oven rear panel (power off, of course). Bosch Part 490358
    Jun 19, 2013 | Bosch HBL 445 Stainless Steel Electric...
    My Bosch oven will not heat
    If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Jan 04, 2011 | Bosch HBL 445 Stainless Steel Electric...
    Tip
    Common heating faults with Bosch HBL 742 / HBL 746 single oven
    on Jan 19, 2010 | Bosch HBL 742 / HBL 746 Electric Single...
    Do you know if a 445 stainless out door grill will rust
    The new 445 stainless has a higher percentage of chromium. It has a better resistance to rustingt that the standard 316 stainless, and is much easier to work with in the manufacturing.
    So , short answer, It will last a very long time in the weather without rusting. ((never say never ??))
    Please Vote !
    Jun 05, 2010 | Bosch HBL 445 Stainless Steel Electric...
    Bosch oven
    looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
    hope this helps
    Jan 17, 2008 | Bosch HBL 745 Stainless Steel Electric...
    Double oven / convection not working
    It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
    Dec 10, 2006 | Bosch HBL 455 Stainless Steel Electric...
    HBL 445
    Nov 25, 2005 | Bosch HBL 445 Stainless Steel Electric...
    Ovens Logo
    Top Bosch Ovens Experts
    ashburton
    paulcarew
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
