Question about Biostar Computers & Internet
How to conect the on off reset
Putting a BIOStar A75MG in an older desktop case. the front panel connecter is different than what was on the case. Is there a way to buy a new one that is manufatured for the motherboard (this conects it to the on off switch in the front of the box) or how tdo I tell what wire is for what on the switch?
  • 5,660 Answers
Biostar Support > A75MG mobo > Main Support page,
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=594&tab=3
[MOtherBOard]
Click on the Download tab.
(Overview / Specification / Accessories / CPU Support / Memory Support ./ Download)
Under the - Manual subheading is -
AA75-M1S_120903_B.zip
Click on the small blue Download Arrow in the sheet paper icon, under the heading - Download.
A small window will come up -
Opening AA75C-M1S_120903_B.zip
Make SURE there is Green dot in the small circle, to the left of -
Save File.
If not; click in the empty circle to the left of - Save File.
Go below in the small window, and click on - OK.
A small download window will come up. Allow the file to fully download, then DOUBLE-click right on the file name.
In the next small window go to the top/left, and under the subheading - Folder Tasks - click on - Extract all files.
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
In the last small window DOUBLE-click on the file to the LEFT -
AA75-M1S_120330 - next to the red Adobe PDF icon.
(The file on the Right is for BIOS information -
AA75C-M1S_BIOS_120903 )
There is the Motherboard Manual.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
You are after the Front Panel header pinout.
The actual manual page number, and the Adobe Reader PDF file page number; DO NOT match. When I refer to a page number it is for the Adobe Reader page number box at top.
(To the right of the Down Arrow)
Go to Page 6 - Motherboard Layout
Panel_1 represents the Front Panel header.
Motherboard installed in computer case, (Processor to Top; Ram memory slots to the Right), there are EIGHT headers along the bottom of the motherboard.
Starting on the LEFT side going towards the Right; the Front Panel header is the 7th header.
(Or 2nd from the Right)
Two rows of contact pins.
Go to Page 15 - Detail Settings - PANEL1: Front Panel header
[Click on the Zoom In icon ( + ) at the Top of the Adobe Reader, to increase the view size.
Use the Zoom Out icon ( - ) to decrease the view size ]
Starting on the LEFT side going towards the Right; TOP row,
Pins 9, 10, NO pin 11, pins 12, 13, 14, 15, and 16.
Starting on the LEFT side going towards the Right; Bottom row,
Pins 1, 2, 3, 4, 5, 6, 7, and 8.
(It is an 8. Whoever printed it out must have been on crack that day)
TOP row;
A) Pins 9 and 10 are N/C. Not Connected
B) There is NO pin 11.
C) Pins 12, 13, and 14 are for the Power On LED.
(Light Emitting Diode, so I will not be stating -> Light. It IS a light)
This is for a Power On LED that has THREE wires.
Dual color Power On LED.
Goes back to the day when there was Turbo, and Normal.
(Usually a Green LED, and a Yellow LED.
Green for Turbo mode, Yellow for Normal mode.
Bunch of cr@p folks!
The Turbo mode was the NORMAL mode. The Normal mode, is the computer is actually slowed down! lol! )
If you have a Power On LED with 2 wires, connect the Positive ( + ) wire to Pin 13, and the Negative ( - ) wire to Pin 14.
(I BELIEVE that's right. If not connect the Positive [ + ] wire to Pin 12, and the Negative [ - ] wire to Pin 14 )
D) Pins 15 and 16 are for the Power On switch. (Power On button)
E) Pins 1 through 4 are for an internal speaker. (Or 'buzzer')
Pin 1 is for the Positive ( + ) wire, Pin 4 is for the Negative ( - ) wire.
F) Pins 5 and 6 are for the HarDDrive activity LED.
Pin 5 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
G) Pins 7 and 8 are for a Reset switch, IF a Reset switch is used.
(I just press the CTRL, ALT, and DELete keys, AT THE SAME time, to restart the computer)
Now you know where the individual wires connect.
Remove the Front Panel. If I knew what old computer case it was, I MAY be able to guide you in removing it.
Most of the time there are 3 TABS coming from the Front Panel, on the open computer case side.
Look inside the open computer case, and at the inside/front near the opening of the computer case.
One tab towards the Top, one towards the Middle, and the last tab towards the Bottom.
The Tabs are plastic, and part of the plastic Front Panel. They go through small rectangular slots, in the metal framework of the computer case.
They have a hooked end on one side.
The Tabs need to be either pressed to the INSIDE, to bring the hooked end to the Middle of the slot, or pressed to the OUTSIDE.
When the hooked end is in the middle, of the slot in the metal framework of the computer case, then the Front Panel can start to be removed.
Start with the Bottom tab. Ease it over so the hooked end is in the middle, of the metal framework metal slot. Ease out on the bottom of the Front Panel, and hold it.
Then ease the hooked end of the Middle tab over.
The Front Panel should start to come off, and you should be able to let go of the bottom, of the Front Panel.
When the Top tab is eased over, the Front Panel will either swing to the opposite side, or start coming straight off.
Look at the wires going to the Front Panel.
You should be able to determine which wires go to the Harddrive activity LED.
There's two wires.
Now look at the wires going to the Power On LED.
The wires usually look as though they go right to that LED.
From there it is just a process of elimination, and you know the last pair of twisted wires go to the Power On switch.
It would be nice to have an inexpensive multimeter, right about now.
They run about $5 to $12. Available at a multitude of stores.
An auto parts store is just one example.
I have seen them on checkout aisle racks, at major discount stores, too.
Multimeter is set to OHM's. (1K)
You check the wires that you think are the Power On switch wires.
If you have the right ones, the reading on the multimeter will 'blip'.
(The Power On switch is a Momentary Contact Switch.
That is why the reading blips, and does not stay on)
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 01, 2013
5 Suggested Answers
campus
  • 56 Answers
SOURCE: ms-6119 front on/off. reset wires disconected from motherboard
http://stason.org/TULARC/pc/motherboards/M/MICRO-STAR-INTERNATIONAL-CO-LTD-Pentium-II-MS-6119.html
If the leds dont light up rotate the plug 180 degrees.
The above site shows you where to place the plugs.
Posted on Nov 29, 2007
ericram
  • 101 Answers
SOURCE: Front panel connections
You can download the complete user manual in English from the manufacturer's website at this link:)
http://support.asus.com/download/download_item_4.aspx?product=1&model=P4B533&SLanguage=en-us&os=17
The front panel connector pinout is on page 2-33, or page 59 in the PDF file. You should have mor ethan enough information to make all the connections you need.
Posted on Jan 02, 2009
  • 165 Answers
SOURCE: Intel Desktop Board D845GERG2 Motherboard front panel plugins
Here is the pinout
http://support.intel.com/support/motherboards/desktop/sb/CS-009016.htm
Posted on Jan 27, 2009
How to remove front panel off my older gateway essential
if it has a molded plastic front panel, most have one version or another of plastic tabs or snaps holding it to a frame.. you just have to try to carefully pry the front away from the case with a thin tool... other types of front panels can be riveted in place and basically not removable..you can usually see what type of construction the case is by removing the side panel and looking at the front panel from the inside...
Jan 04, 2014 | Gateway Computers & Internet
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
How to connect panel 1 of n68s3+
pin #'s
Dec 22, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
I have a old atx case new mobo no front sound
make sure the front panel jacks is connected, chek the motherboard manual to c how to connect
Oct 08, 2009 | Biostar G31-M7 TE Motherboard
Analog front panel conections need map to board connections
Here your connection...
Front pannel
http://www.geocities.com/jisfy/Front-P.JPG
Front Pannel Usb Connection
http://www.geocities.com/jisfy/USB.JPG
Thanks if it helpfull please rate me.
Mar 26, 2009 | Biostar M7VKQ-PRO Motherboard
Wiring a P4M80-M4 mother board
You can download the manual for the motherboard here, just click on the "manual" link:
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=246
This will list the front panel connections, which are 2 pins. Each of the jumpers, what you are calling clips, will connect two of the pins. Most cases have the jumpers labeled, i.e. power, reset, etc. But if they are not, it is usually: red/white = HDD led; green/white = power led; red/black = speaker; black/green = power switch; and black/white = reset. But your case may use a different wiring spec, but should list somewhere which wire is for which function.
Feb 28, 2008 | Computers & Internet
No manual
here is a link to your mhttp://www.biostar.com.tw/upload/Manual/P4M80M4_0119C_B.exe - this will show you the front header panel for hooking up the power.
Sep 12, 2007 | Biostar P4M80-M4 Motherboard
Panel 1 settings
Hello ocea, Here is a link to the manual: ftp://ftp.biostar-usa.com/manuals/M7VKF/M7VKFmanual.pdf Here is a picture of the front panel settings:
Oct 14, 2006 | Biostar M7VKF Motherboard
Computers & Internet Logo
420 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
