Question about Vehicle Parts & Accessories
My viper alarm is not locking the car doors
I recently change the battery on my car and notices that the doors where not looking. Everything else works fine.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
  • 5 Answers
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
Posted on Oct 09, 2009
  • 33 Answers
SOURCE: battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Posted on Oct 23, 2009
SOURCE: Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Posted on Nov 25, 2009
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My Viper Alarm started going off while I was driving. I pulled over, shut everything off. Got out of the car and closed the door and locking and unlocking the vehicle wouldn't shut the car off. I opened...
The alarm may not be going off. Rather it may be a malfunction of the relay that is driving all the sirens and piezo. Next time it happens check for flashing parking lights. They will flash only when alarm is going off. Also ignition input to the alarm prevents this alarm from going off while driving. Panic from the remote can still be triggered. Got to play detective....
Feb 27, 2017 | Viper Vehicle Parts & Accessories
My remote will say that its locked but my car alarm wont sound to say its locked, OR ALARM when i lock the door would be open....also the blue LED light that normally blinks when the systems are alright is...
Your alarm is in valet.Open the driver's door, press lock, unlock, lock. The blue light should go out and the chirps should sound when locking and unlocking now.
Feb 27, 2011 | Remote Start System
My viper 5002 alarm i don't know witch wire's to use off the viper alarm's for the power lock's
The door lock wires for the Viper alarm are green (-)lock and blue (-) unlock. The Viper system only provides a negative lock/unlock pulse for the door locks. So, if you are working on a vehicle that has positive door locks you will have to install relays to change the polarity.
Nov 08, 2010 | 5002 2 Way Car Alarm with Keyless Entry...
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Disable viper alarm
Jan 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
97 Jaguar XJ6 No Start (good battery- no click)
when you battery goes dead, the security system locks the car. When you charge the bathery, use the key to lock the door and hold until the alarm activates. open your door and you can now start your car...dmakia@gmail.com
Mar 16, 2009 | 1997 Jaguar XJ6
Alarm goes off for no reason 20-30 minutes after i lock doors
remove the battery from your remote and see if works
Mar 12, 2009 | 2001 Dodge Viper
Vehicle Parts & Accessories Logo
283 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
