Question about Winter Sports
Have a 2005 Polaris 550 Trail, problem is it won't idle. Runs good but when I stop it dies and is hard to start again.
Where is voltage regultor? seld runs awsome...sat for 3 years cleaned out both carbs new plugs nothing in air box...rode it all weekend no problems beside it will not idle and perk reverse will not work? HELP PLEASE!
Posted on Jan 10, 2013
  • dookieisthem
    dookieisthem Jan 10, 2013
    where is voltage regultor? seld runs awsome...sat for 3 years cleaned out both carbs new plugs no **** in air box...rode it all weekend no problems beside it will not idle and perk reverse will not work? HELP PLEASE!
4 Suggested Answers
  • 12 Answers
SOURCE: 2003 polaris 550 trail touring,revearse not working
the high idle could be a dirty needle check your carbs i have that problem with my 550 rmk the reverse light could be your wire harness check your wires with any wire tester idk the specs for it but also clean your connections with some electrical wire component cleaner and use so di-electrical grease if all else fails you may need to bring it to a mechanic for a small fix like that it should run up that high
Posted on Aug 14, 2009
  • 35 Answers
SOURCE: 05 polaris fusion running great down trail.then
your coil went out, the spark plug wires go directly to it, they go out periodocally. the wire from that goes to the magneto
Posted on Feb 17, 2010
  • 46 Answers
SOURCE: dim lights hand warmers aren't heating prperly on
IT IS MOST LIKELY YOUR VOLTAGE REGULATOR
Posted on Jan 06, 2011
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
Why won't 1981 suzuki gs 550 bike won't start after riding it and it's warmed up?
hi
glad i served a long time with wisco and used drag raced for them at one time
sounds to me that your ignition is to far retarded
which means the ignition will spark closer to (TDC)
top dead center
some people advanced the ignition 3 deg to stop the engine from smoking when they did away with 4 star fuel
and gave us unleaded fuel
doing this the performance is great and fast acceleration
but it also make the engine run hotter than normal
unless you have up jetted the carbs
and fitted a non standard exhaust system
the whole idea is get the fuel/air mixture in and out as fast as possible
if you still have points
take your points cover off and adjust your points baseplate
undo the three screws that hold it in place
and just move it about 3 deg towards the rear of the engine
or may be you have a electronic ignition fitted
if so do the same thing
and advance the ignition 3 deg
hope this works for you
ride safe
Sep 18, 2017 | 1982 Suzuki Gs 550 L
1987 polaris trail boss 250 manual
hi, i have a 1987 polaris trail boss 4x4 was riding and gas was leaking from the under side front of gas tank, is there a hose from the carb there? Anyway when i noticed the gas leak we stopped and it slowly ideled down until it died and then would not start.
I have spark pulled carb and cleaned i get gas.
can you help?
Jun 01, 2012 | Polaris ATV
Trail boss looses power when placed in reverse.
you have to push in the override button in reverse
Nov 29, 2011 | Polaris ATV
I recently bought a Suzuki gs 550 and need to reduce idle speed i don't know how to do this at the carb
the idle adjustment screw is located between the number 2 and 3 carburator float bowls bottom rear. I can bairly get my hand on it, but found that a flat blade screwdriver works fine for making ajustments. backing out the screw lowers the idle speed, while running it in increases it. To adjust make sure the motor is warmed up and the choke is off. Make adjustments from the right side (looking at bike from the back), by pushing with the screwdriver on the knurals of the adjustment knob, pushing knurals up backs the screw out, conversly down runs it in. Try for around 1000 rpms for your set speed. You want it to idle smooth and low, but you want it set so it won't die out when you come to a stop when you are riding. If you can not get the idle in this range, then there is some other problem needing attention. However, the idle at times may run a little bit higher than normal when you come to a stop after a hard ride, and should return to normal set speed after it cools down some. You should also make sure that the throttle cable is set at the proper tenion, if too tight, you won't be able to lower the idle. you may have to make adjustments a few times to get it right.
Jun 12, 2011 | 1980 Suzuki Gs 550 L
2001 polaris trail boss. it kept running very rough, no power, and died frequently, hard to start. acted like it was flooded. i opened the oil fill to check the oil level and it was so full it came running...
This happened to me with my trailboss also last week.
Take the carb off and clean it completely/ Drain the oil/
Put carb back on / Refill with new oil
your good to go.
(I had to clean the carb 2 times before it didn't to it again.
I was told the choke was stuck open or something.
Hope this helps!
Mar 06, 2010 | Polaris ATV
Feb 23, 2009 | Polaris New Genuine Polaris Snowmobile...
Winter Sports Logo
193 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
