Question about Kitchen Appliances - Others
Savoureux pro line meat slicer, instructions for cleaning
5 Suggested Answers
SOURCE: Globe commercial Meat slicer
Hi, I have working on meat slicer my whole life and can help you.
What normally happens is this. The bearings in the knife hub (this is the unit that the knife attaches to and spins) is starting to fail.
The gear on the knife hub is made out of a fiberous material and the worm gear on the motor is made out of metal, so when the bearings start to fail and cause resitance in the hub, the metal motor gear starts to eat the fiber gear on the hub and eventually wears a big chuck out of it. Then the motor spins free and doesn't make contact with the hub gear.
How you can check if this is the problem is this. You need to keep the power switch on machine in the off position and turn the blade a 1/4 of a revolution. Then turn the machine on, what should happen is that the blade will spin some and stop again.
The proper fix for the machine would be to rebuilt the knife bearing unit and replace the hub gear, motor gear and hardware.
In regards to the Chefmate. This is a design flaw of Globe and I told them about this when the machine first came out! The know is on a steel shaft that goes thru the aluminum body. The steel shaft starts to corode and also rust, then it freeze in the frame. What has to be done is this. This assembly needs to taken about sanded, lubed and put back together. The best way to permently fix this is have a machine shop machine the frame out and install a Oilite Bushing, these are impregnated with oil and it will never lock up again.
Where are you located? Let me know if I can answer any other questions for you.
If you have any other questions, you can call me on my cell 201-274-6274 or e-mail me at njrealestate@earthlink.net. Thank you
Best regards,
Scott
Posted on Dec 27, 2008
protek480
  • 1723 Answers
SOURCE: how old do you have to be to clean a meat slicer
Old enough to know that you unplug it before you work on the blade!
Posted on Sep 26, 2009
SOURCE: Rival Meat Slicer Model 1037 Pin for blade
i too need a pin for this modle. has anyone solved this problem for that person?
Posted on Sep 15, 2010
SOURCE: looking for a part for
Hi, did you ever get the worm gear? I need one for the same machine.
Posted on Jul 15, 2011
Bolt and washer for rival meat slicer mod 1101e/3
Meat Slicer Parts ' eBay
www.ebay.com/bhp/meat-slicer-parts
  1. Cached
  2. Similar
Meat Slicer RIVAL 1101E/4 Motor Plastic Washer Replacement Part Vintage ... Rival Food Slicer Meat Motor Holder SCREW 1101E-5 Accessory Spare Part.
Rival Meat Slicer ' eBay
www.ebay.com/bhp/rival-meat-slicer
  1. Cached
  2. Similar
Vintage Rival Electr-O-Matic Deli Meat Food Slicer 1101E-2. $45.00; Buy .... Meat Slicer RIVAL 1101E/4 Motor Plastic Washer Replacement Part Vintage. $7.99.
Food Prep & Choppers - Rival Products
www.rivalproducts.com/...manuals/food.../food-prep-and-choppers-manual.html
  1. Cached
  2. Similar
HM-743 - Rival® Hand Mixer Instruction Manual · 1042-WN - Rival® Folding Food Slicer Manual · CN-742 - Rival® Electric Can Opener Instruction Manual ... rival meat slicer mod 1101e 3 Google Search
Dec 23, 2016 | Rival Food Processors
Model EH8804. Where can I get a replacement switch?
That is a specialised switch as it looks oval and is a three position switch on, off reverse. It _may_ be a standard switch underneath and the button is separate. A new grinder is only 40 bucks here
http://www.heartlandamerica.com/savoureux-pro-liner-meat-grinder.html
If you take it apart, you may be able to ID the switch on these images?
http://www.bing.com/images/search?q=replacement+switches&FORM=HDRSC2
Mar 10, 2016 | SAVOUREUX PRO LINE Meat Grinder
Meat slicer: when slicing our pork loin the meat will stick up under the blade at the bottom causing the meat to spin off the slicer?
The blade may require cleaning in between usage as the oils and sugars are solidifying on the blade from previous usage causing the meats to adhere to the blade when sliced.
Dec 22, 2013 | Kitchen Appliances - Others
Savoureux pro line ice cream maker
How can I get the recipes for the Savoureux Pro line o\ice cream maker? I can down load the manual.
Feb 03, 2012 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
111 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
