Zannusi banging When on spin it gets really loud and sounds as if its banging on the side
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
It sounds like it's unbalanced. Try redistributing the clothes and/or washing smaller loads. If that doesn't fix the problem, you may need to call out a technician.
Posted on Dec 31, 2012
fanny
  • 146 Answers
SOURCE: Loud bang during spin
Remove the top of the machine and check if the centralising spring/s is/are still attatched. Next remove back cover or tilt machine back and inspected the shock absorbers. One of the shockies could be broken or just pulled out of the guide. If springs and shockies are ok open the door and try to move the inner drum up, down and sideways. If it is very loose, then the centre bearing is worn.
Posted on Nov 03, 2007
  • 249 Answers
SOURCE: Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Posted on Dec 17, 2007
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
beltronic205
  • 1466 Answers
SOURCE: loud banging noise during spin cycle on front
Could be a broken spring on top of the drum allowing it to hit back of casing...hope you fix...
Posted on Oct 10, 2009
kel1guy2002
  • 3740 Answers
SOURCE: loud banging noise during washing cycle. Sounds
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
Posted on Mar 07, 2010
What is causing the tub of my top load washer to bang against the back side of the washer while it is in the spin cycle? The washer also vibrates violently.
sounds like the damping system is the problem. The drum may have moved out of place or the damper(s) have become faulty in some manner. I used to have a hotpoint washer that tried to destroy the room it was in by travelling around it after the drum had fallen off its mounts. I bought a new machine, my thinking being that there is no point in taking a risk of having a real disaster if I set it to wash and then go out.
Bosch / zannusi / siemens make good machines
Dec 18, 2015 | Washing Machines
GE front load is making loud banging noise during spin, any ideas how to fix?
Sounds like what happens in a top load when the load is "out of balance". I suppose it's less likely to occur with front load. Test with a "light" load. Is the washing action a reversing action? If so there may be a transmission problem.
Apr 11, 2015 | GE Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Open the cabinet top and check along the sides for a broken or out-of-position damper. Shake the mechanism in several directions to help locate. Hope this helps!
Jun 12, 2010 | Kenmore HE2 Plus Front Load Washer
Zannusi fl 1082 very loud banging noise when spinning
This is most likely due to an unbalanced load. The drom on the washer is only mounted at the bottom and if your load is heavy on one side, when it spins, the centrifigual force will make the inner drum hit the outer and bang. When you hear this happenning, open the lid, drag some of the wet items from the heavy side to the light side and close the lid again. The banging should go away. If you want to see what is happenning (though you MUST BE CAREFUL when doing this), activate the spin with the lid open by suing a stick or small screwdriver to press on the switch that is normally depressed by a post on the lid. The unit will 'think' the lid is closed and will resume its cycle. You should see the major wobble during the spin. NEVER PUT YOUR HANDS IN THE WASHER WHILE IT IS MOVING>
Aug 21, 2009 | Washing Machines
Kenmore washer loud bang in spin
Great!! Thanks for the followup -- I mean really, thanks!!
May 02, 2009 | Washing Machines
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Loud knocking sound
You have a bad drive block. This block is located under the inner tub. A special spanner wrench is required to remove the tub. You really need to call a service tech for this repair.
Apr 15, 2009 | Whirlpool LSB6200KQ Top Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
