Question about Jenn-Air Cooktops
Jenn-Air Model CVG4280W gas downdraft cook top front burner does not light even though gas is going to it. The back burner lights perfectly. The same happens on the left side burners. What part do I need?
textonor
  • 130 Answers
SOURCE: Thermadore gas stove top - left 2 burners won't light
Either the potentiors or the simmer control.
Posted on Jan 06, 2008
dauphine
  • 207 Answers
SOURCE: No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Posted on Apr 09, 2008
  • 222 Answers
SOURCE: why does my jenn gas cook top burners all flicker when turned off
hi im gerbee,i will sujest to clean the area were is the place of ur knob control try to remove the control knob then clean it by using a vaccium coz sometimes the problem is very dirt of the control knob.
Posted on Dec 02, 2008
SOURCE: Jenn-Air electric stove top - burners/fan won't come on
I had the same problem. Went to an appliance store that carries Jenn Air. Replaced both plug in units. Now they work perfectly and it cost less than $350 total! Good Luck!
Posted on Dec 12, 2008
jtbjtb
  • 135 Answers
SOURCE: Jenn-Air electric burner goes to full no matter what the setting
This would be a faulty switch. Hope this helps!
Posted on Feb 17, 2009
Gas burner won't light unless gas is turned down to the low position.
I've had this happen before,first make sure that the black burner cap is clean underneath and it's making good contact with the aluminium burner,also make sure the igniter is sparking across to the burner, check the ceramic coating around the igniter isn't cracked or the wires shorting out . Good luck.
Feb 20, 2014 | Jenn-Air Cooktops
I have a gas glass cook top (JGC9536) with a problem at the right front surface burner (12,500 btu). I used to be able to just turn the switch on high and the burner would light. Now, there is spark and...
Make sure there is no blockage of the burner near where the spark jumps. All it takes is a drop of water to stop the gas flow near the spark. Most likely you can use a knife or some other thin blade to clear the slots where the flame comes out of the burner.
Feb 20, 2014 | Jenn-Air 35 in. JGC9536 Gas Cooktop
I have a Jenn Air gas cooktop, only about 2 years
If the burner just clicks and won't stare try this (a local tech showed me) Scrape the underside of the burner cap (the removable black disk in the middle of the burner) with a key or knife and watch it work! But be ready to do it again and again. There's a glossy finish left by the factory he said.
Jan 03, 2010 | Jenn-Air Cooktops
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Downdraft Slide-In Range
I have the radiant cooktop (i.e., glass top) version of this range. I've had this same problem since I first purchased this unit. I wondered why no one answered this question, as I check back to see from time to time. I finally contacted Jenn-Air's online support. My conversation was as follows (I'm not entirely sure that the tech support knew what she was talking about, but here you go anyway):
message.gif?p_db_name=whirlpool Cidalia C: Hi, my name is Cidalia C. How may I help you?
message.gif?p_db_name=whirlpool You: Hello!
message.gif?p_db_name=whirlpool You: I have a question regarding my "Downdraft Radiant Cooktop"
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air today with your inquiry. What is your question please?
message.gif?p_db_name=whirlpool You: None of my burners can simmer-- no matter what the setting, they will boil water!
message.gif?p_db_name=whirlpool You: Is there an adjustment that can be made to attenuate the heat?
message.gif?p_db_name=whirlpool Cidalia C: What is the model number of your cook top please
message.gif?p_db_name=whirlpool You: JED8430ADB
message.gif?p_db_name=whirlpool Cidalia C: Thank you. In looking at your burner configuration, the smallest wattage on your unit is 1200. And, unfortunately, there is no way to get a small wattage for your burners. We apologize for the inconvenience.
message.gif?p_db_name=whirlpool You: Yes, but the dials are supposed to prevent the full 1200 watts from reaching the burner unless it's on maximum heat, correct?
message.gif?p_db_name=whirlpool Cidalia C: Yes, but the burners do not get low enough to be considered simmer burners.
message.gif?p_db_name=whirlpool Cidalia C: Did you have any other questions or concerns today?
message.gif?p_db_name=whirlpool You: I suppose not.
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air. Have a good day!
Jul 08, 2008 | Jenn-Air JED8430 Electric Cooktop
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Cooktops Logo
60 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
