Question about Whirlpool RF364 Electric Kitchen Range
Whirlpool Oven - Model RF368LXMS - oven is not working
Freestanding oven is 5 years old. Used oven yesterday and it worked fine. This morning I tried to use it and oven would not heat to correct temperature. Both elements are not heating (top or bottom). Smoothtop range is still working.
catriver
  • 878 Answers
SOURCE: Whirlpool Freestanding Range Flashing E1,F2 and beeping!!!
farkle, outside of Gendos's excellent advice, the issue could be with the keypad. If your model has a keypad ribbon that attaches to the main board, remove it and take a eraser and clean the ends. Then reinsert it. On the board there should be two clips on the end where the ribbon attaches. Lift these up and the ribbon will pull out. See if this solves the problem...Catriver.
Posted on Dec 25, 2006
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
Amigaman
  • 248 Answers
SOURCE: broil element will not work
You need to check the oven sensor. It should be about 11k ohms. This is the metal rod in the back top of oven cavity. Access it from the rear. UNPLUG POWER FIRST!!
Posted on Nov 04, 2007
  • 3422 Answers
SOURCE: whirlpool Standard Cleaning Electric Rang Model RF315PXKQ
hi,
Can you please tell me if you have replaced the thermostat?If not then please do that.
Waiting for your reply.
Posted on Feb 24, 2008
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
My electric Amana Range with self cleaning oven model Art6100 or Art6000 approx. 11 years old will not work on the clean cycle. Burners and oven work fine. We had the door off and apart to clean a few days...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Microwave will not turn on -- light does not come
Chances are good that you have a bad door switch.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 22, 2010 | Whirlpool RMC275PD Microwave Oven
The oven won't lock shut for cleaning
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My oven will not heat up at all.
make sure your cooking timer is on manual....
Feb 01, 2009 | Whirlpool RBS305PD Electric Single Oven
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Oven too hot!!
sounds like a bad oven temp sensor, small 3-6 inch, metal probe in upper left corner of inner cavity, 2 screws and the sensor should pull right out, replace you should be fine
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool double oven
water or over spray in the panel let dry for couple days and turn back on see what happens
May 08, 2008 | Ovens
Whirlpool RF364 Electric Kitchen Range Logo
277 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
