Question about Music
Crate glx 212 has no sound - Music
2 Suggested Answers
guitarmanjoe
  • 336 Answers
SOURCE: Crate GLX-212 combo. cant change DSP. repair??
The last knob on the right should give 16 different effects, are you saying the knob doesn't work at all? Is it turning smoothly? Do you hear any clicks as you turn it? Is anything plugged into the dsp socket on the back where the footswitch would go?
Posted on Mar 14, 2013
I have a crate vtx 212 amp and the power comes on but none of the chanels comes on and no sound what so ever comes out. Nothing looks burnt or corroded idk what the problem is i need help lol
If sure that power is reaching and getting into unit, then confirm that a signal is also reaching unit. If both are positive, then your gear is FUBAR if signal is going into correct input.
Feb 13, 2017 | Crate Music
My crate amp makes a static sound when i turn controls and the cord input port makes noise when moving it around
Most likely a loose connection. Try to tighten the knobs and the cord port to the crate. You need to do this from the inside. These tend to loosen with use and anything that is connected with them will also loosen, like the electrical connections. Good luck!
Feb 20, 2016 | Crate Music
I just picked up a Crate VTX 212 amp. It sounds great! However, it hums a little louder than it should. I'm thinking it's a bad ground somewhere? Anyone out there deal with this before?
Check your guitar with another amp, or a different guitar with this one with no effects pedals, etc, to narrow it down to just the amp. At that point, try reversing the polarity. If none of the above helps, you may indeed have a bad ground somewhere and you'll need a tech to follow it to the source.
Aug 16, 2015 | Crate Music
Frying sound from amp intermittantly
then the problen is in the power amp section after the preamp stage. Contact Crate for your nearest service center.
http://www.crateamps.com/support/index.php
Mar 03, 2014 | Crate Ca6110dg Gunnison 60 Watt Acoustic...
Mar 13, 2013 | Music
CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN SHUT OFF. NEED SCHEMATIC AND ADVICE TO ISOLATE THE BAD CAP IN WHICH CIRCUIT THAT IT IS OSCILLATING.
Witth an oscilloscope analyze the ripple voltage across C67, C70, C14, and C12. Pay close attention to the last two of these which are on +/- 15 volt lines.
The "chirp" when shutting down is LIKELY normal and would probably be from teh DSP effects unit as it goes down. The voltages go out of the operating range and the device essentially goes nuts for a second or so.
Sep 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
A 700 series Line 6 Variax,noisy hiss
The hissing is caused by a bad connection, most likely at the cable jack. Try replacing it and while you're doing that check the rest of the components - especially the potentiometers, used ones generate a lot of static.
Jan 26, 2010 | Line 6 Variax 700 6 String Modeling Guitar...
Crate Bass Amp B100 - No sound.
Do you happen to have another speaker that you could hook up to speaker output? This would bypass the amps internal speaker and lf you get sound from that setup, it would mean either a jack failure or possible internal speaker problems. Please let me know.
Jan 24, 2010 | Crate Music
Music Logo
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
