Question about Teac Televison & Video
We have a teac led lcd tv model le55beafhd the remote control is not responding to the tv. tried new batteries but won't even turn the tv on and off -and I can't see any blue light from the e
3 Suggested Answers
danbusa
  • 185 Answers
SOURCE: Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Posted on Apr 19, 2011
Testimonial: "Thanks for the tip on the Power scan. I was trying the power scan described on some other webpage and it didn't seem to work. Your tip was dead on "
SOURCE: my samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Posted on Dec 13, 2011
Remote control not working brand new sony rm-lj301 remote
Check the remote control for its infra-red emission. Even new pieces might have the fault. You can check its infra-red emission, by a mobile phone having camera option. If you wish to get more details about how to check a remote control, check this link.http://electronicshelponline.blogspot.com/ If the remote control emits infra-red emission, and still TV do not respond to it, the fault will be due to a damaged infrared sensor inside TV. This part can be located just behind the infrared window at the front panel of the TV set. You have to open the TV, to access it and to replace with a new one. The part will look somewhat like these.
Jun 11, 2013 | Televison & Video
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
Remote Control won't start TV
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jun 14, 2017 | Toshiba 22AV500U 22 in. LCD TV
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
Dec 13, 2011 | Televison & Video
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
Remote fOR AOC LCD L37W781B won't work
try to replace a crystal capasitor on your remote
Feb 21, 2009 | AOC A15X221 15 in. LCD Television
TV does not respond to Remote
possible defective rf receiver led defective in the tv.
Nov 21, 2006 | Toshiba 32AF43 32" TV
Televison & Video Logo
53 people viewed this question
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
