Question about Garden
Compression spec for a craftsman 42 cc chainsaw
What are the compression specs for this saw?
SOURCE: start a chainsaw
took it to a shop
Posted on Jan 15, 2009
  • 2692 Answers
SOURCE: need parts for ryobi pcn3335
http://www.ryobitools.com/parts
Posted on Jan 18, 2009
  • 83 Answers
SOURCE: 46 cc Sears/Poulan chainsaw will not start
Four things I can think of:
1) There is a short in your spark plug wire. When you bend it to connect the plug in the machine it allows the exposed cable to contact the engine block. Examine the wire all the way to the coil.
2) Flywheel key is sheared ( you obviously know how to take off the flywheel since you checked the seals).
3) Flywheel air gap is not set correctly. Loosen the coil. Put the cover of a notebook or the cardboard piece of a cigarette pack between the magnetic portion of the flywheel and the coil. Tighten the coil down. This will get you the proper gap.
4) Your cylinder/piston or rings are scrubbed out. Even though it passed a compression test, on rare occasions it will loose compression only when it fires. So do the following:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
First if you can get a inline spark tester so you can see if your getting spark with the plug installed.
Posted on Mar 31, 2009
slohry
  • 87 Answers
SOURCE: Owners manual for Craftsman 20 in chain saw, needed
Parts manual, have model # available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 09, 2009
dontbother10
  • 2220 Answers
SOURCE: specs on 4620avx chain
Both questions are answered on page 16 here (if original chain):
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2010/NOUS2010_545186802.pdf
Quite a few of the questions on this page apply to your undertaking.
http://www.oregonchain.com/pro/service/faq.htm
Please take few minutes to read any that may remotely apply. A few minutes spent here may prevent the frustration of a chain that will not cut straight through teh log.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
A craftsman 50cc chainsaw that backfires and dies
How long since you did tune up? Suggest looking at ingniton point condition, if clean adjust gap to spec for saw engine. You may have to replace the condenser.
Jan 28, 2015 | Craftsman Garden
Settings for carb. on a 42 cc chain saw
Initial settings are one full turn CCW on both low and high side adjustments.
Sep 02, 2014 | Craftsman sears 18" Chain Saw Chain (...
Torque specs
LOOKING FOR KIA PICANTO BIG ENDS BOLT TORQUE
Jan 01, 2014 | Craftsman sears 18" Chain Saw Chain (...
Have Chain Saw Craftsman Model 358.350811, 40 CC Engine 2 Cycle : What Engine Compression should I be reading when I test it ? Also, what is Factory Setting for IDLE SCREW(2 turns out from closed, etc)...
The compression has to be at minimum 100 PSI for a 2 stroke. Some will run under 100 PSI. Turn the screws all the way in very gently and back them both out 1 full turn. This will at least get you started.
Aug 27, 2013 | Craftsman Garden
HOMELITE 27AV CHAINSAW WILL NOT START. CLEANED CARB, PLUG GETS GOOD SPARK. TRIED EVERYTHING.
Hi chuckbjr44,
Have you checked the compression ?The way to do that is take the plug out and ground the plug wire by tying it out of the way so that it touches on some metal .Use a compression gauge while a friend pulls the rope.It sounds like rings to me. Thank you for using Fix Ya. ps you can a local repair shop for the specs on the right compression for your saw.
May 11, 2011 | Homelite Garden
Need fuel mixture specs
50:1 is the fuel to oil ratio using a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to mix the fuel and oil in it's own container, and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Feb 03, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
I have a new 18'' craftsman, couldnt resist the price 42 cc, but i want a bigger chain, it has a standard 3/8 small chain for trimming branches, I know to do this will require a different bar and sprocket...
Many time the big chain stores (like Sears, Wal Mart, etc.) will have products made to their own specs (re:cheaper), which makes getting replacement parts difficult at best and impossible at worst. Another reason they do this is so that you won't be able to find the exact same model elsewhere at a better price and force them to match or beat it. It's entirely possible that if you can't find the longer bar & chain at Sears, you won't find it anywhere.
Jan 30, 2010 | Garden
I have a XL12 UT 10445A and I need to find out the specs and also it is not gettting any spark
I do not have any specs on it, but parts are available.
The saw can have either points/condensor and/or electronic ignition
No-start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Nov 13, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Sep 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
