Question about Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker
My crate glx 212 powers up but has no sound - Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker
2 Suggested Answers
  • 12962 Answers
SOURCE: I have a crate vtx 212 amp and the power comes on but none of the chanels comes on and no sound what so ever comes out. Nothing looks burnt or corroded idk what the problem is i need help lol
If sure that power is reaching and getting into unit, then confirm that a signal is also reaching unit. If both are positive, then your gear is FUBAR if signal is going into correct input.
Posted on Feb 13, 2017
Feb 13, 2017 | Crate Music
I just picked up a Crate VTX 212 amp. It sounds great! However, it hums a little louder than it should. I'm thinking it's a bad ground somewhere? Anyone out there deal with this before?
Check your guitar with another amp, or a different guitar with this one with no effects pedals, etc, to narrow it down to just the amp. At that point, try reversing the polarity. If none of the above helps, you may indeed have a bad ground somewhere and you'll need a tech to follow it to the source.
Aug 16, 2015 | Crate Music
Frying sound from amp intermittantly
then the problen is in the power amp section after the preamp stage. Contact Crate for your nearest service center.
http://www.crateamps.com/support/index.php
Mar 03, 2014 | Crate Ca6110dg Gunnison 60 Watt Acoustic...
Valveking 212 combo shows lamp lights but power tubes are not lighting no sound
no filament power then, filament fuse open..blown winding on transformer, regulator bad..You an ET with shop full of tools...then we can get to work...
Dec 31, 2013 | Peavey ValveKing 100w All Tube 212 Combo...
Crate GLX-212 combo. cant change DSP. repair??
The last knob on the right should give 16 different effects, are you saying the knob doesn't work at all? Is it turning smoothly? Do you hear any clicks as you turn it? Is anything plugged into the dsp socket on the back where the footswitch would go?
Mar 13, 2013 | Music
Crate pa6fx powered mixer, powers on but when I hook speakers up to them, hear loud hissing and pops out of one of the speakers, nothing out of the other. I can hook up a mic and hear myself through the...
It is likely that there is a failure of one of the amps in the unit. It could be a cracked circuit board, bad solder, bad volume control, or a bad compnent in the power amp section for one side. HOWEVER something does NOT compute here as you can't connect more than one speaker to a 15 Watt Crate amp... Maybe you have two of these amps.
Dec 27, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN SHUT OFF. NEED SCHEMATIC AND ADVICE TO ISOLATE THE BAD CAP IN WHICH CIRCUIT THAT IT IS OSCILLATING.
Witth an oscilloscope analyze the ripple voltage across C67, C70, C14, and C12. Pay close attention to the last two of these which are on +/- 15 volt lines.
The "chirp" when shutting down is LIKELY normal and would probably be from teh DSP effects unit as it goes down. The voltages go out of the operating range and the device essentially goes nuts for a second or so.
Sep 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a small crate rx15 solid state amp. The
This is likely a power supply failure OR the amp chip is bad, It is probablly in the TDA family such as a TDA2050
May 15, 2010 | Music
I have a small crate rx15 solid state amp. The power light comes on, but no sound comes out of either the amp or headphone jack. No buzz etc....
Power light means very little. If unit has a preamp output, plug a set of headphones into it and see if you can hear anythin going through. (it will be weak). If you can, the power amp section is bad. Take in for service.
Mar 29, 2010 | Crate Music
Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker Logo
96 people viewed this question
Top Crate Music Experts
Michial Gueffroy
Ben Armstrong
richie46
Are you a Crate Music Expert? Answer questions, earn points and help others
