When I start my washer it says sensing and it makes a load humming noise. It does this on every setting and I made sure that the door was shut all the way.
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
Love your doggie! THe loud sound sounds like the motor, but the control panel is not letting the cycle begin. Sensing means it is looking for water to begin filling the machine. If there is no water going into the machine this means that the solenoid that allows water to enter the machine is not opening the valve or maybe, YOU DIDN"T TURN ON THE WATER AT THE FAUCETS!
Posted on Dec 31, 2012
zeusfaber
  • 247 Answers
SOURCE: front load washer
Easy things first: Check the water hoses are all connected, the taps are on, and that the hoses aren't kinked. Everything after that involves poking around live terminals. If you aren't happy doing this, then don't be ashamed to call someone else in. Turn the power off. Remove the top panel from the machine. On the inside of the back panel near the top, you will find the fill valves (on a few machines, there is only the one). These are the items that the fill hoses you checked a minute ago plug into. Follow the hoses inside the machine from the soap dispenser back to the valves to identify which valve is the one which washes soap into the machine at the very start of the cycle. On the top of this valve are two terminals. Attach the leads of a multimeter to these, and select an ac volts range that will stand seeing mains voltage. (If you haven't got a multimeter, suggest you buy a cheap one from the local hardware shop - it will come in handy for all sorts of things once you have it). Turn the machine on and start a wash cycle. If the meter shows mains voltage across the terminals of the valve, and yet no water is flowing into the machine, you need to replace the valve. This is a cheap part to buy, and not difficult to do yourself. IF you don't find any volts across the valve, it's worth trying the other valves to make sure you haven't got the wrong one, but then it's beginning to look like a controller problem - at which point it's worth paying someone else to come in and look at it: Once expensive parts get involved, you either need to be sure you know what's broken, or be sure you can take unneeded, but briefly installed replacement parts back. Before removing your meter leads, don't forget to turn the power off. A.
Posted on Jun 30, 2007
aborcass
  • 2651 Answers
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Posted on Oct 19, 2008
SOURCE: ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Posted on Sep 04, 2009
  • 6 Answers
SOURCE: Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Posted on Nov 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: WHIRLPOOL TOP LOAD WASHER-LSQ7030LQO- MACHINE
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
The sensing light is off and not spinning out good
Hi talknbrenda - First, does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Other possibilities could be a faulty door lock, timer, pump, or control board not communicating correctly. In this case I would contact a professional to move forward accurately to properly diagnose and repair the washer.
Nov 09, 2012 | Frigidaire Affinity ATF7000E Front Load...
I just replaced the door lock mechanism and then started the washer and when it came to drain and spin , it shut down PLEASE HELP?? not sure what to do now, when I put it to spin it just makes a buzzing...
Hello - First, does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. From what you have described, if the door lock assembly has been replaced and issue continues then the unit could possibly be experiencing an issue with the timer, control board not communicating correctly or a faulty pump. In this case I would contact a professional to move forward accurately since it is not recommened to be used if it is providing a burnt smell to properly diagnose and repair the washer.
Nov 07, 2012 | Frigidaire Affinity ATF7000E Front Load...
Front load washer stopped working
What is the model number listed on the washer?
Oct 13, 2012 | Washing Machines
The washer won't start and is making a humming noise and displaying Ld
LD IS FOR LONG DRAIN. , If it takes to long to drain the computer will shut in down. Either some clothing has gotten under the basket and is restricting the water flow to the drain pump,or the drain pump its self is damaged. when the senses all the water has not been pumped out it will let the washer start
Sep 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
I have a zanussi turbo dry built-in washer/dryer built-in 1200, Mod zjd . 125, and I do not know how to use it. HELP! Thanks, Cindy
Hey, Just load the washer but do not over load. These combo washer dryers are strictly for smaller loads. You should have a drawer to the left that you place the soap and softer and bleach. Set to the washer to washer. The door should lock automatically. Then set your dryer setting to the the Heat temperature that you want. 100 degrees is ok to start with. then it will adjust itself as it goes through the cycles you have set. Enjoy the machine should work. If it does not look to make sure that the door is closed all the way. Sometimes you have to open the door and reset it and shut the door or while it is closed gently push on it till you hear a small clicking noise. ENJOY YOUR WASHER DRYER COMBO
Aug 28, 2009 | Washing Machines
Hot or cold water won't come on
If there's no water at all, make these checks:
  • Is there water getting to the machine?
    Check to be sure that someone did not turn off the water, usually the faucet or faucets are on the wall behind the machine.
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Aug 03, 2009 | GE WDSR2080D Top Load Washer
Moved to new home hooked everything up washer will not fill
ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
A humming sound in the cycle knob
Make sure that the room is quiet then check that there is a clicking noise from the lid when it is nearly closed
If not then the microswitch is out of whack and needs adjusting
When you slam the door down it is probably enough to make the switch but then the machines movement will undo that action
Jun 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
