No cold water coming into washer - Washing Machines
  • 51 Answers
There is a screen in the water inlet valve that gets clogged. Turn off both hot and cold water, take off the cold water line and clean screen out. If screen is clean, set to cold water wash and turn on the washer. You should hear the solenoid hum. If you hum, check the leads to the cold water solenoid. With the washer set on cold and turned on you should read 110VAC across the wires. If you have voltage the solenoid is bad. If no voltage, broken wire or timer problem.
Posted on Dec 31, 2012
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
Cold and hot water switch
Switch the hoses where the water comes in the washer.
Aug 23, 2012 | Kenmore Elite 45986 Front Load Washer
Water for intial fill works fine . when it goes to rinse cycle the water just dribbles in making wash time go on for ever ! whats the solution?
when you start the washer set it just on cold and see if it fills slowly,when the washer goes to rinse it just uses cold water,you could have a problem with the washer or in the house,when you run it on just cold and if it dribbles in,stop it shut down the water going to the washer,remove the cold water hose from the back of the washer,stick it in the sink or inside the washer and turn it on,if it comes out strong then you have a bad water valve on the washer,if it comes out slowly you have a bad water valve in the house and it's not the washer.hope this helps
Sep 12, 2011 | Washing Machines
Have a old maytag want to know if its fixable for cheap model LAT8414AAE will final spin but no water is coming out yes the water is on and its getting power help!
when it goes into the final rinse the washer just uses cold water no matter what you have the setting on, start the washer and flip the setting to cold,does the water come into the washer?try it on hot and check that,if no water coming out on one of the settings do this shut the valve off to the water that feeds the washer,mark the hoses so you'll know where they went and disconnect them from the back of the washer,stick them into the washer or a sink or bucket and turn the water back on,if water is coming out of both hoses you'll know the trouble is just with the washer and i'd say the cold water solenoid on the water valve on the washer is bad and you'll need to replace the valve.
Apr 23, 2011 | Maytag Washing Machines
I have Kenmore washer. Anytime the selection is on cold, warm and cold, hot and cold the washer makes squicky noise and very little water come out even though both hot and cold water are open. the only...
from what you said it sounds like you have a problem with cold water coming into the machine,shut off the house water valve,remove the water lines off the back of the washer and mark them so you'll know where the connect when you put them back onto the washer,stick them in a backet or in the tub of the washer,turn the water on,if the water comes out strong then you have a problem with the water valve on the washer,see if you can pull out the screens out of the valve and clean them but most likely you'll need to replace the valve.if the water doesn't come out strong then you have a problem with the house water
Feb 22, 2011 | Kenmore Washing Machines
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Cold water not coming into washer
Turn off cold water valve and unscrew the cold water inlet hose off the machine. Dig the filter screen out of the valve, clean it, and re-install screen, hose, and turn water back on. If that does not fix it, replace water valve.
Jun 19, 2010 | Kenmore 22422 Top Load Washer
Cannot get cold water to come into the washer
Turn off the water and reverse the hot and cold water connections going into the faucet, then turn the water back on. If only cold water comes out of the unit when on hot temperature then you need to order a water valve solenoid which I suspect is the problem or wash only in cold water. They are replaced by removing the back washer panel a couple of bolts, one connector, and two hose clamps. Remember to restore the hot and cold water connections.
Jul 14, 2009 | Whirlpool Washing Machines
Whirlpool washer approximately 2 1/2 year old
The screen at the cold water inlet is clogged. Cut off the cold water line and unscrew the line to the washer at the washer. Use a flathead screwdriver and pry out the metal screen that is visible Wash it out in a sink and re-install it. Re-attach the water line,turn it on and your'e good to go. If not you will need a new water inlet valve. These are the only things that can cause your problem unless there is a problem with your cold water supply pressure. Good Luck!!!!!
barneyluc
Oct 03, 2008 | Washing Machines
GE Washer wbsr3140d5ww water problem
Hello Chad
Welcome
Sounds like the cold water knob or switch is not switching and may be faulty.
I have a problem with my washer
For some reason when I try to start the washer and I have it set to cold it does not work if I put it to hot then its fine
The cold water does work though because if I change the washer to a later cycle cold water comes out just fine.
So it almost seems like its the timer knob
any ideas?
Thanks
Please remember to leave a rating
Jun 04, 2007 | GE WBSR3140D Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
