Question about Toys
I can't get my crayola marker airbrush to spray
I'm having a problem as well with the correct insertion of the markers (being too far inserted which causes foamy bubbles, or not in far enough, where nothing but air comes out). But now my main problem is that the canister is not holding air at all. I can pump away just to hear the air escaping from the main unit before I can even have time to use the sprayer. Is there a way to fix this? Or has anyone else had these problems?
Posted on Jan 08, 2015
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Is the head clogged? Try running the head where the spray comes out under hot water and then use it.
Posted on Dec 31, 2012
    Genius:
  • 1,669 Answers
The video doesn't tell me anything! I must conclude that the tip of the airbrush is not allowing paint to flow. First see if the air pump is working by removing the tip completely. If it is then the tip can be cleaned with the tools in the airbrush kit!
How do I keep crayola super tip markers from drying out
Always store them in a box, in a cool, dry, dark place. If they seem dried out, before you chuck them out, TRY THIS! Grab the tip with needle nosed pliers, gently pull the nibs out, lay them on paper towels and slowly pour a little water on them. Replace the nib using the pliers, be sure to get it all the way back in. Replace the caps and let them rest on their side for a good couple hours. THIS HAS WORKED LIKE A CHARM FOR ME, NUMEROUS TIMES!
If you cant open them, dip the tips of the markers in warm water for a few seconds, replacing the caps tightly and set them on their side overnight, or for a few good hours. Hope this helps!
Dec 07, 2015 | Crayola Crafts & Hobbies
CRAYOLA AIRBRUSH ONLY SPRAYS AIR
Did you check for obstructions on the airbrush?
Dec 26, 2013 | Crayola Marker Airbrush Set
How can I tell the difference between airbrushes and spray-guns?
Airbrushes are hand-held and used instead of a brush for detailed work. Spray guns can be either automated or hand-held and have interchangeable heads to allow for different spray patterns.
Feb 03, 2013 | Crafts & Hobbies
What is an air brush?
An airbrush is a small, air-operated tool that sprays various media including ink and dye. Spray guns were developed from the airbrush and are still considered a type of airbrush.
Won't spray
There are a lot of variables while airbrushing. If you are having trouble with a new airbrush(or one that isn't hugely gunked up) you likely need to do 1 or both of the following to get it to spray the paint:
1) Thin your paint, use the correct medium based on the paint type. Water can be used to thin water-based paints but too much will result in a bad coat and finish. You are looking for a milk-slightly thicker than milker consistency.
2) Crank up the air through the airbrush. Assuming you have a regulator you may need to turn the pressure up to get thicker paints to spray. If you are using a siphon feed you may need a couple extra PSI to recoup for what you are losing from the syphon. Make sure to check the max pressure your airbrush can handle before cranking it too high(most can handle at least 30 PSI).
Hope this helps.
Jan 23, 2013 | Airbrush-Depot Master Airbrush Model G23...
Is there an instruction manual for the Master Airbrush Model S68?
i am not getting the paint to spray from the paint cup please help
Dec 15, 2010 | Master Heaters Master Airbrush Model G75...
Spraying paint instead of air for the first action
Make sure the needle is pushed completely up against the tip. You will possibly have to take the back handle off to adjust it. (I am not familiar with this paint gun specifically). Make sure you do not force the needle into the tip, gentley push it until it stops.
I hope this helps.
Nov 10, 2009 | RTO Dual-action Side-feed Trigger...
Need a new paasche spray gun for bigger jobs
Anest-Iwata brand spray equipment has the most versatile line of airbrushes on the market. Im sure you will find one to meet your needs. well worth the money, it's all I spray
http://www.airbrush-iwata.com/
http://www.tcpglobal.com/airbrushdepot/iwata.aspx
check it out!!
Apr 07, 2009 | Air Tools & Compressors
Total Novice
I suggest that you go to the Library and look up how to airbrush. The paint goes into the cup. Nozzle adjustments are learned as you go, for desired results. Good luck
Feb 01, 2009 | Badger Basket Starter Spray Gun Hobby Set
Toys Logo
979 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
