Question about Canon Pixma MP480 All-In-One InkJet Printer
Remove print head canon mp480
I just replaced the ink on my MP 480 after it had been sitting idle for several months. Apparently, the print heads are clogged. I have tried using the utility to perform both a cleaning and deep cleaning, but some colors still won't print. How do I remove the print head to clean it manually?
    Genius:
  • 1,669 Answers
THe print heads are an integral part of each cartridge. When you remove the cartridges you actually remove the print heads. You will need to open the top front panel to access the print carriage which moves left and right over the paper under it. Using cotton swabs you can apply rubbing alcohol to the places the cartridges rest upon and absorb all the dried out ink. Be sure you toss the old cartridges out before you reassemble. If you need to store any ink type printers REMOVE ALL CARTRIDGES and clean off the receivers on the print carriage!
Posted on Dec 31, 2012
SOURCE: Can anyone tell me how to remove the print head?
Take out the cartridges first, then the printhead will come out easily. Grab it at the top, and gently Pull out. That'll do it good Luck!!
Posted on May 31, 2007
SOURCE: MP 360 won't print
the Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
Posted on Feb 25, 2008
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
tenorsax
SOURCE: Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Posted on Aug 17, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
How do you change inks in a canon pixma mp 480 printer
Here is a screen shot taken from the Canon On-screen manual . Below is the link where you can download a copy of this manual which gives step-by-step instructions with pictures on how to replace an ink tank. :
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp480#BrochuresAndManuals
To read the screenshot, simply zoom in by pressing ctrl++ at the same time until the you can read the font.
Apr 20, 2011 | Canon PIXMA MP470 All-in-One Printer
I have a Canon Inkjet i475D printer that has been sitting for a year or more. I've tried to use it today - and the print heads are apparently clogged. I've tried the cleaning and deep cleaning utility...
if its been sat for a year it will need new cartridges. ink drys out over time when empty it drys to the head as there is nothing to keep it wet.
May 15, 2017 | Canon i475 InkJet Printer
Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
Oct 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
Cannon i 860 can't get the cyan to print - have run cleaning operation several times deep cleaning @ least twive & checked ink tank visually put new ink tank in put a Q tip to the head there is ink -...
Then try this, it works for me!!!
Canon will hate me for this.
1. Remove ink cartridges.
2. Remove print head.
3. Go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head being careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air-dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 06, 2008 | Office Equipment & Supplies
Magenta ink ran out,continued to use printer,replaced ink tank twice,have done cleaning & deep cleaning several times no magenta coming through,all other colours ok. what to do next?? anybody have...
Think you may have killed your print head, but try this.
OK, Canon will hate me for posting this.
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
13. Start printing.
Jul 01, 2008 | Canon Office Equipment & Supplies
Pixma IP4000 Printer
OK, Canon will hate me for posting this!!!!!
Remove cartridges.
Remove print head.
Go to sink or tub (stianless steel, not pastic type), pick up roll of paper towel on the way.
Run HOT water till HOT.
Turn hot water to dribble.
Run hot water through print head, careful not to wet contacts.
When water is clear coming through print head, place print head on paper towel.
Repeat process until no colour on paper towel.
DAB print head (DO NOT WIPE) inside and out to dry.
You may wish to let print head air dry overnight but I replace it after drying.
Replace print head in printer and replace cartridges.
Start printing again
I do this on all my Canon printrs every 6 months
Jun 30, 2008 | Office Equipment & Supplies
Mp 360
I had exaclty same problem - black not printing - was about to buy a new printer but did the following as a last resort about a month ago - remove the ink cartridges - removed the head and sat it on an a tissue - into the 'well' where the printer cartridges sit I dropped into there a very small amount of water as if to 'wash it through' where the ink would flow, (about a quarter tea spoon) - agitated it a bit - this flushed thru the gaps were the ink goes - I cleaned it all up - dried it with a tissue - put it all back together - it works fine now ! This was a last resort option for me but I guarantee it did work !
Oct 11, 2007 | Canon MultiPASS MP360 All-In-One InkJet...
Canon Pixma MP480 All-In-One InkJet Printer Logo
764 people viewed this question
old marine
old marine
