Question about Neff U1721 Double circotherm Electric Oven
Lower oven not heating up everything else is working fine
I have a NEFF U1721 double oven(ENR No U1721N2GB/05). The lower oven has just decided not to heat up although both the fan and light are working normally. If you think it is the heating element could you please advise where I am best to get one and how easy it is to fit. many thanks Roy
Hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Posted on Feb 26, 2009
My Neff U1721 oven does not heat up, Element
YOU CAN BYPASS IT HOWEVER BEAR IN MY THIS IS A SAFTEY DEVICE AN MAY HAVE FAILED BECAUSE OVEN OVERHEATED,( FIRE RISK PRESENT) IF THIS IS THE CASE, A BYPASS SHOULD BE CONSIDERD VERY TEMPORARY.
Jun 10, 2010 | Neff U1721 Double circotherm Electric Oven
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Lower oven not giving out any heat, fan working, light working
If fan is working ok, then you need to fit a new oven element, located at rear of oven behind a removeable cover.
Please rate my soution.
Thanks.
Nov 18, 2009 | Neff U1721 Double circotherm Electric Oven
How do I find out what model my Neff is please - it is a double stainless steel oven purchased in 2000 ish
open the bottom oven door and you will find a small silver plate on the left side of the oven frame. the model number follows the letters "ENR".
Jun 26, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
No heat generated in lower oven
You are quite correct in saying that the element has failed.
As regards the wattage , it should be stamped on the fixing plate of the element, if you cannot see it there then opt for the lower wattage one, it will not make much difference to the oven ,as there is only100watt difference between the 2., and that is nothing to worry about.
Plz rate my solution to your prob.
Thanks.
Jan 03, 2009 | Neff U1721 Double circotherm Electric Oven
Can not remove element
Hi there. Dunno if you solved your problem but I had exactly the same. I did a bit of digging on this website and found the solution which worked. Basically, undo the three bolts holding the fan motor onto the back of the unit. This should allow enough play on the fan from the inside to wiggle (technical term) the bolt free and replace on the new element. Reposition and secure the motor. Hope this helps. Matt
Apr 02, 2008 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
669 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
