Question about Toshiba 50L2200U 50" 1080p LED-LCD TV - 16:9 - HDTV 1080p
Picture too big on my toshiba 50l2200u
Images too large to fit on screen. How do I adjust back to factory setting
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: usergiude toshiba 50l2200u
Google the model number with manual or visit the Toshiba site with the same.
Posted on Sep 01, 2012
Carnt get normal screen on my tv the picture is always to large
Look for an option in your TV settings that allows you to adjust the screen size, once found, adjust to your actual TV screen and it should in theory fit perfectly.
May 31, 2015 | Televison & Video
How do i reduce the size of the images on my screen
Increase the resolution and the images will shrink down to fit appropriately in the new size screen.
Oct 05, 2014 | Nokia Lumia 1520 Red Factory Unlocked...
Picture is too large for screen
HelloPicture adjustments should be done to get correct picture size. All these adjustments are given on page [16] of the user manual. It is not possible to include all illustrations here by this window. According to the manual, just do factory default. Proceedings are there. OK.
Dec 19, 2011 | Dynex DX-L19-10A LCD TV
After being on a few minutes, the text becomes very blurry I lowered the resolution, which makes the text bigger and helps some. There is an internal adjustment, but I don't know where??
Hi hamptonwhh,
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges. Please follow the steps below on how to adjust your screen resolution.
Windows XP
1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3. When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Windows Vista/7
1. Open Display Settings by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Notes : When you change the screen resolution, it affects all users who log on to the computer.
When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution.
Hope it helps.
Thank you for using FixYa.
Jul 04, 2011 | MPC Computers Envision EN 775e 17 in.CRT...
Text on screen too large and cannot get to fit on
Sounds as though your screen is in zoom mode. Have a look on the remote for an option button like "aspect" or 16:9/4:3
May 31, 2010 | Samsung Televison & Video
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Hp Compaq FS7600 17" monitor screen adjustment needed
Um, lets see. Does any of the buttons work? Try and find a button that will switch settings back to factory default. If not go to control panel and change the screen resolution to see if that helps in the mean time.
Jun 26, 2009 | HP Compaq FS7600 17" CRT Monitor
The images are too big.
go to the printer perference or setting on your pc, there is option says scale to fit the page, click it , and some of printer allow you to select the paper size you are using. its simple problem its just driver setting issue.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 19, 2009 | Dell Office Equipment & Supplies
Monitor resolution
Sounds like either the trapazoidal is off or the pincushion is set improperly. You should be able to find those settings via the monitors onboard menu. Either one can create such a problem.
You might also check into finding the factory defaults selection. This will reset all of the resolutions and refresh rate settings.
When you adjust your screen follow these steps in order...
Pincushion : Makes the screen look like ( ) or ) (
Trapazoidal : Makes the screen look like / \ or \ /
Horizontal : Basically stretches the screen wider or skinnier to fit the monitor
Vertical : Basically the same as Horizontal, only with the up and down properties
Contrast / Brightness : Use this to find the perfect white and blacks
Color : Finish your setup with adjusting to the perfect color.
This way you can always have your monitor set like you want it.
Sep 12, 2008 | Gateway FPD2275W LCD Monitor
How do I adjust the resolution that the photos are saved?
To change the resolution and compression:
1. Press the Func button.
2. Scroll down, if necessary, to the icon in the lower left corner of the LCD.
3. Use the right or left arrows to select L (large), M1, M2 (medium), or S (small). Press the Set button.
4. Use the right or left arrows to select superfine (quadrant with S), fine (quadrant), or normal (stairsteps). Press the Set button.
5. Press the Func button to exit.
Large/superfine images will take up the most space on the memory card. Small/normal images will take the least, but the picture quality will be less if you're printing the pictures.
There is a table at this link (scroll down) to show you how many images will fit on a memory card at different settings.
May 09, 2008 | Canon PowerShot S1 IS Digital Camera
Toshiba 50L2200U 50" 1080p LED-LCD TV - 16:9 - HDTV 1080p Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
