Question about Amana NFW7300WW 4.0 cu. ft. Front Load Washer
Amana front load washer stopped working & is just making a humming noise
There is no "error code" displayed
2 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Posted on Nov 05, 2011
My washer wash but does't dry
Hello noriel17 - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 28, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6700FS2 pauses with every load
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 04, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire LTF530FS Front Load Washing Machine. It stopped draining and spinning. The drain pump had an underwire from a bra stuck in it. We removed that and cleaned the pump. Hooked everything...
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Since you hear a humming noise, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 28, 2012 | Frigidaire FTF530FS Front Load Washer
I have a frigidaire front load washer. When I start a new load it starts with a couple of seconds of water then stops. Does not go into a wash mode, the timer shows it's going thru the cycles but
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 08, 2012 | Frigidaire Affinity ATF7000E Front Load...
Amana front load washer error code "nd". Door is
Nov 05, 2011 | Amana Washing Machines
9 minutes into the express wash cycle, the washer stopped and is now flashing "F" the "21"
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
May 29, 2011 | Kenmore Front Load Washer
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
Amana NFW7300WW 4.0 cu. ft. Front Load Washer Logo
44 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
