Question about Toshiba 2860 Copier
Replace the ink with pictures - Toshiba 2860 Copier
How do i change the cartilage
Step by step instructions, along with pictures can be found at the following site,
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx340#ServiceAndSupport
1.When you get to the site, click on " Service and Support ".
2.In the question search box type " replace ink cartridge ", then press the "search arrow ".
3. Under the search results, click on " How do I replace the ink cartridge (s) ? "
4. The instructions along with pictures will be displayed for you.
5.Follow the steps listed on the page for correct replacement of ink.
Feb 23, 2011 | Canon MX340 AllInOne InkJet Printer
Screen shows picture of printer cartridge holder and message "waste ink absorber is almost full"
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
May 21, 2010 | Canon PIXMA iP90 Mobile Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
Black ink not printing
Dear Friend, Check & confirm the following will help you...
  • Check ink tank situates Properly
  • OR Install recommended Ink tanks in Perfect Order
  • OR Remove Tape[Confirm there is no Orange tape across the top of ink tank]] From the Ink tank
  • OR Replace Ink tank
  • OR Perform Deep Print Head Cleaning
  • OR The Print Head may Need Replacing
>i860_install_inks_animation Click here
Above picture is the Correct View.... If this helped you,Do rate ME...Thanks For Contacting FixYa....
Apr 22, 2010 | Canon i860 InkJet Photo Printer
Out of ink
In case you have not already found a solution....
Go to:
MP620 Support
Select the "Support & Service" tab if it is not already showing.
Type insert ink tank in the space to "Please enter your question" block.
"How do I replace or insert an ink tank?" should be the first result showing.
Click on that link and it will open up detailed instructions with pictures on replacing the ink.
Thanks for using Fixya.
Apr 27, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Low Ink
Considering this is a high quality printer this is very well possible. If it was a spiderman picture it may have just used a lot of magenta for its color mixing. Print some regular low quality images not full size and see what happens to your ink. If your worried about high price ink you can visit a site where they sell 3rd party ink that is much cheaper.
Feb 01, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Copier wont print color picture from computer
Please call 1.800.421.6699 and select option 01 for prints missing black or color ink. Kodak will send you a replacement printhead kit for free. I hope this helps.
Jan 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon Copier
TRY UNINSTALLING THE DRIVES COMPLETELY  THEN REINSTALLING THEM.........mAKE SURE YOU HAVE THE SAME EXACT CARTRIDGE
Oct 09, 2007 | Canon BJC 8200 InkJet Printer
16 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
