Question about Samsung Dryers
Samsung DV220AEW/XAA NOT HEATING
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 16 Answers
The heating coils have sensors that will interrupt the power going to the coils which create heat, take a meter and test voltage to each wire on the sensors, if one side of the sensor has voltage and the other doesnt the sensor is bad, replace it or pull the wires off and jump them or tie them together to see if it works, but you will burn your house down if you dont use the sensor, so get it replaced asap
Posted on Jan 01, 2013
2 Suggested Answers
RyanFanMan
  • 342 Answers
SOURCE: Samsung Model DV220AEW/XAA 7.3 CU
sounds like the heating element has gone or the themal component has died. you can test it with a multimeter by setting it to ohms and putting it across the terminals of the heater and if you get a reading then it is not an open circuit after that test the thermal cutoff the same way if it has a reading then it is good but if it stays at 0 then it is no good
Posted on Mar 04, 2011
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
I have samsung dv220aew/xaa dryer, that gets too hot and kicks code HE. New element, thermistor and cleaned thoroughly. Gets hot, codes on all heat settings. Any ideas?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Apr 21, 2015 | Samsung Dryers
I have a Samsung dv220aew xaa dryer that does not produce heat. I've replaced the heating element, the thermistor, and the thermostats with the problem remaining, what could be the problem?
ARE U GETTING THE RIGHT AMOUNT OF VOLTAGE AT THE CONNECTION,? i VE SEEN IN SOME CASES WHERE THE MACHINE ONLY GETTING 120 AND WILL RUN BUT NOT CREATE MUCH HEAT? THE DRYER USES 120 TO RUN THE CYCLE BUT NEEDS A FULL 220 FOR THE HEAT CYCLE TO WORK, THUS IF UR MISSING VOLTAGE IT WILL NOT HEAT? ANOTHER CULPRIT COULD BE A BAD TIMER STUCK ON COOL DOWN OR FLUFF CYCLE AND WILL PRODUCE NO HEAT?
Sep 25, 2014 | Dryers
Is there a reset on a Samsung dryer model number DV220AEW/XAA
normally if u unplug it for a couple minutes then plug back in , may reset . also try putting it on the on position then open and close the lid slightly 6 times withing 12 seconds, it may reset it
Jun 03, 2014 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
My Samsung DV5451AEW/XAA will not dry cloths. The vent tube is not plugged and air flow is great through the whole vent system. How do I get to the heating element?
  • I am assuming this is electric. Yes?
  • Do you get any heat when there is no clothes in it?
  • Have you checked your voltage at the receptacle? If not 220V, if you have the old tube fuses, then one may be blown. If you are getting good heat with no clothes then replace your high limit thermostat. Lots to check before heading for the heating element. As for heating element they are usually either in the back of the tub or a tube on the right hand side of the dryer. You need to take the front panel off.
Aug 03, 2013 | Samsung White Dryer Dv5451aew/xaa
Samsung Model DV220AEW/XAA 7.3 CU FT 7 cycle. No HOT air comes out!!! HELP?
Mar 04, 2011 | Samsung DV337 Electric Dryer
My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
Samsung DV337AEW/XAA wont turn off by timer. we
The timer has gone out rplaceit and all should be fine
Oct 27, 2009 | Samsung DV337 Electric Dryer
Dryers Logo
189 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
