SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked.
The nd error code indicates "no drain". If the unit can't drain it won't
spin. You're going to have to slide the washer out far enough to remove
the rear panel; be careful not to damage the floor. Once you get the
rear panel off you will see the pump. Be sure to have plenty of towels
& a small container to catch water. I am sending you instructions
from the service manual to remove and replace the pump. Another
possibility is the drain line is blocked or something is stuck in the
tub to pump hose.
SOURCE: Amana front load washer hums only
A centrifugal switch to allow the motor to start up on the start winding and once started it opens to take it out of the start winding. The motor has to have voltage applied to the start winding and the run winding at the same time in order for the motor to start. The capacitor is part of the start circuit. When the motor goes to start, the voltage must be applied to the start winding in order for the motor to start or it will just hum. The moment the motor reaches a certain RPM the centrifugal switch opens up to remove the start voltage to the motor and it will remain running on the run winding. The motor will not start up on run voltage alone. It needs both, the start voltage and run voltage. I think the problem is that the motor is not getting the start voltage supplied to the motor or the start winding has opened up in the motor.
Hello Deanna Lytle - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
