Question about Roper Washing Machines
Roper model ral5144awo - Roper Washing Machines
2 Suggested Answers
  • 254 Answers
SOURCE: the agitator is not turning but i can hear the
AGIT DOGS ,,, go get or order whirlpool part number 80040
replace those and you should be good to go.. they are under the cap and have lil grippers on them that wear down and help rotate the agaitator assy..
Posted on Jan 28, 2010
How to remove inner tub of Roper Washer, scraping sound coming from underneath every cycle of tub
Go to www.repairclinic.com and enter model of your Roper washing machine. With luck you will be presented with a list of common replacement parts an may be able to view a generic Roper disassembly video.
Jul 22, 2017 | Roper Washing Machines
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
The agitator is not turning but i can hear the mechanism turning inside the agitator. is there a sheer pin broken? this is a roper heavy duty / large cap.( model #ral5144awo) top load washer.
Jan 28, 2010 | Roper Washing Machines
Roper model RAS7133PQO everyting works except it
Gee it could be anything from something in the pump to a bad main transmission gear. Here is some repair pictures and a few good manuals
Sep 09, 2009 | Roper Washing Machines
Have a Roper Model RAS7133RQ1 washer turns on won't wash etc
hi there i think the problem is that your big end has blown and this is affecting your gangle pin you will need to replace these and these are very cheap and available from any hardware shop your friend MR FIXIT
Apr 26, 2009 | Roper Washing Machines
I bought a new property which has a Roper Dryer Model REX4635EWO and a Roper washer model RAB5232EW. NO MANUALS!
Roper is made by Whirlpool. The Roper website is down and under construction. Contact Whirlpool either by email or telephone. They may be able to give you the info you are looking for.
http://www.whirlpool.com/custserv/index.jsp
Apr 18, 2009 | Dryers
I have a roper washer that wont spin. Probably the coupler. I have changed couplers many times on other types of washers whirlpool amana and kenmore. etc. is the process the same with a roper ?
exact same as a whirlpool, for they own roper, amanas do not have couplers..... the kenmore might if the model starts with 110.********* or 118.*********
Jan 16, 2009 | Roper RAX4232KQ Top Load Washer
Adjetator (sp) isn't spinning properly .
The agitator dogs (little dog ear gears) are stripped. This is a very easy fix and the new dogs are very cheap. Go down to an appliance part store and ask them for agitator dogs for a direct drive whirlpool washer. Ill help too with installtion
Jan 12, 2008 | Washing Machines
Agitator-How do you get it off?
(Roper is actually made by Whirlpool) This is simpler than it sounds, just takes time and a few steps. Do you have a fabric softener dispenser that resides on top of the agitator? This dispenser simply snaps onto the top of the agitator. Some styles use a decorative cap. To remove the dispenser, simply grab it and firmly pull up. There is a cap that covers the bolt or nut that holds the agitator in place. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (the part that moves). Use a twisting or prying action to pop the cap off of the agitator. Sometimes there is a little slot where you can insert the screwdriver. Look for it first. There maybe an internal debris cap under this: Inside the agitator you will see a cap with a raised handle. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring. Removing the agitator: When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt or nut from the agitator stud. Don't use plyers, it'll just mess up the nut. With the bolt removed you should be able to remove the agitator by simply pulling up. Twist back and forth CW & CCW when lifting. Some are a 2 piece design, so pulling up will actually remove either the whole agitator assembly or only half of it. If whole assy comes up and you may need to seperate the two for your new parts. Place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator. As far as your parts go I'm not sure where they go without seeing it myself. There is a spline or ratch assembly which causes the agitator to move back and forth. They are usually made of plastic and get worn or break. This might be what you are replacing. It's not clear as to what parts they gave you. Good Luck
Jul 17, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
78 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
