Question about Samsung HT-DM550 System
Samsung ht-thx22 keeps cutting out
The home cinema system keeps cuttin out after 10-15 mins and says protection and goes on standby
  • d_a_j10 Feb 26, 2009
    Same problem here. Is there anyone who can help?
5 Suggested Answers
SOURCE: dvd multiregion unlock code
Perfectly it work on the SAMSUNG HT X40
Posted on Oct 18, 2008
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
bogue-engine
  • 24 Answers
SOURCE: ht-z210 home cinema protect error
Protection Error means that there is a malfunctioning component inside your unit. It will go into protection mode and immediately shut down to protect your system from any further damage. Unfortunately you would have to bring it to a dealer or repair shop to diagnose the exact malfunction and that could be expensive.
Gary
Posted on Jul 22, 2009
SOURCE: SAMSUNG DIGITAL HOME CINEMA SYSTEM MODEL HT-Z110
Maybe the audio amplifier Ic are damaged and need to be replaced
Posted on Aug 14, 2009
  • 25 Answers
SOURCE: samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Posted on Aug 26, 2009
Sound fades out on my Samsung ht-thx22 system
Please check the drivers and see if this section is heating up, If so there is possibilty that there is a thermal runaway or there is dry soldering on the board. You can check for heating or simulate the heat to confirm the case, if not the use of a freeze-it spray can cool the suspected component to be confirmed.
Oct 22, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
I have a samsung home cinema ht-tz212 keep saying protect and not working
its most likely over heated. Try removing the plug and moving it away from the tv and any heated areas for atleast a day, then try turning it on and it should work..
If it only goes into protect when you put a dvd in then change the regional code.
Feb 26, 2010 | Samsung Audio Players & Recorders
Samsung hiome cinema protect error message
Aug 04, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Ht-z210 home cinema protect error
Gary
Jul 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Protection Error
maybe the audio amplifier IC´s are in bad conditions and need to be replaced
Jun 30, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Protection displayed and shuts off When I press the power button Protection is appear on screen on my home cinema system dvd player
check wiring on speakers it sounds like you have some wires touching together somewhere or you have a bad speaker.
Jun 15, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Hello I have a Samsung HT-HTX22 home cinema. It wont play any discs at all, it says Loading then reads no disc or disc error, can any one help. Regards Joe
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
Apr 11, 2009 | Samsung HT-Z310T Theater System
Disc Unknown keeps coming up on the screen
check the dust content on in the m,achine then check your settings to make sure its adjust accordingly
Mar 30, 2009 | Samsung HT-DM550 System
Audio
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
Mar 21, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Dvd multiregion unlock code
use the procedure for unlocking the Samsung HT-DM150 .
Oct 28, 2007 | Audio Players & Recorders
Samsung HT-DM550 System Logo
266 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
sonic boom...
sonic boom...
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
