Question about Apple iPod MA446LL/A MP3 Player
Ipod will not recharge
The Ipod gets extremely hot and will not charge. I have tried the wall socket and also the UBS port on the computer. I have left it charge overnight and in the morning I have just enough power to turn it on. The battery icon shows a very slight red line. Please help me... I'm desperate.... I use this everyday at work. Thanks in advance. Rae
  • 432 Answers
See if anybody at you job has an Ipod and use there battery charger. It may be the battery charge and not the Ipod.
Posted on Jun 24, 2007
SOURCE:
IPod Touch 4th gen won't charge with from a wall socket
Have you tried different outlets? I have an outlet in my room that won't charge my devices all of a sudden for some odd reason.
Dec 02, 2013 | Apple Audio Players & Recorders
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
There is no sound or display on the screen when it is power on
The Apple iPod uses a rechargeable, lithium-based battery that can go between 10 and 36 hours between charges, depending on the model. You can charge your iPod using either an electrical outlet or your computer's USB port, but if you find that your iPod no longer takes or maintains a charge despite having the right connections, you should try some basic troubleshooting methods to restore the device's battery life.
Connect your iPod to a different USB port or wall outlet. If you use a USB port to charge your iPod, you may simply have a low-powered port, according to Apple. You can often resolve this by switching the cable to a different port, or using a wall charger (sold separately) to recharge instead. Charge your iPod for several hours. If you find your iPod completely unresponsive even as it charges, leave it plugged in for three or four hours and check again. If your battery life has been depleted completely, the iPod will need time before it can begin functioning again. Restart your iPod. A frozen or dysfunctional iPod may fail to charge, but a quick reset can fix basic functionality glitches. To reset a touch-wheel iPod, hold down the "Select" and "Menu" buttons until the gray Apple emblem appears on the screen. For iPod Touch, hold down the "Sleep" and "Home" buttons (the only two buttons on the device). Connect your iPod to your PC using the provided USB cable, open the iTunes software and click the "iPod" tab in the left column. Then click the "Update" button to search for and install the latest iPod software. Apple recommends keeping your software up-to-date to ensure that your battery life remains fully optimized. Purchase a new battery from Apple. If your battery fails to charge despite all your troubleshooting efforts, it may simply be too old and depleted to continue functioning. By taking advantage of Apple's iPod Out-of-Warranty Battery Replacement Program (see Link Below), you can send in your iPod and receive a replacement battery or replacement http://www.apple.com/support/ipod/service/battery/ iPod for a modest fee.
Feb 11, 2013 | Apple iPod Audio Players & Recorders
After charging and unplugging from the USB port of my computer, the iPod screen goes blank and won't come back on. I have tried resetting, but no luck. Just in case it matters, I had not used it for quite...
Have you got a normal wall charger is so it is smarter to use that, becuase when you charge the nano or any ipod for that matter, it slowly makes the battery life shorter so i suggest start charging from the wall charger, but it might be too late but give it a go if you have one hope this helped
Dec 12, 2009 | Apple iPod nano
My ipod won't charge. keeps saying "please wait. very low battery" what's wrong with it?
I had the same problem. Went to the Apple store and the technician said that the IPOD battery ran down to low (battery level showed red) and the USB port on the computer was not strong enough to recharge it. He used a rechargeable adapter that pluged directly into the wall (adapter cost about $30) and recharged it enough for me to take it home and recharge it on my computer.He said to never let the battery level drop below 5% unless you are going to recharge it using the adapter that pluged into the wall. I bought an IPOD rechargeable travel kit from Target for $20 and used it to recharge my IPOD. My IPOD works fine now. The Technician also said at some point the battery will need to be replaced (in a year or two depends). Will cost about $59 to replace it (don't quote me on the timeframe or price of replacement, this may have been just for my IPOD but thought this would be useful info for someone.
Nov 24, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod 4 GB not charging and gets very Hot when I try to charg
my nano 4gb ipod gets hot when i try and charge it on conputor ac ports it gets hot
Mar 18, 2009 | Apple iPod nano
160 gb ipod classic won't recharge with the wall charger
Try charging it on the computer or with a different wall charger. The fault may lie in the charger brick. I have seen it happen many times that the wall charger quits working but it still charges on the computer.
Cheers
Nov 14, 2008 | Apple iPod classic MP3 Player
How to recharge mastero fron computer useing ubs port
You can try charging the unit with the supplied uSb cable but the output on the USB is so low that it might only partially charge the battery or it will take eons to charge
Feb 11, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Apple iPod MA446LL/A MP3 Player Logo
69 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
