Question about Dryers
My Kenmore washer gets down to 2 minutes and then stops. Tub has water in base of it and clothes are dripping wet. No matter how I try to custom spin and dry, the ending is the same. 2 minutes and
We do not have an owners manual to either the washer or dryer. By the way, the coordinating dryer also has gone bonkers on the same day!!!! The tub light is on, but no other lights on front. Nothing will work.
  • 163 Answers
SOURCE: Washer spins but not enough to extract water from clothes or tub.
it sound to me to be the water pump, with all the water in the tub, the machine dont spin ok, and the water is extracted by centifugal force, not by pumping as it should be, call a tech, this is a hard job for regular people..good luck
Posted on Aug 10, 2006
hotuna
  • 288 Answers
SOURCE: Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Posted on Dec 18, 2007
SOURCE: G E dryer
check the drum slides, they are bushings that make sure the dryer has thrust but not too much. If they wear out the drum has too much movement back and forth and clothes will get caught in between the drum and the dyer housing, and might not turn if its get caught at a funny angle inside the housing.
Posted on Dec 30, 2007
aborcass
  • 2651 Answers
SOURCE: Dryer tub won't turn
hear the motor running, just not spinnig drum? if so you problably eiteh threw the belt off pully it broke all together. theres 2 screws holding the front panel on apprx 10 in. up and 2in. in, slightly pointed upwards. rmeove them and the front panl comes off, i believ the top might just tip back at that pint in which case youll see the belt wrapped around the drum. ro where it should be wrapped around anyway. new belt num Y312959.if needed, youll need to reach beltto motor pulley from behind unit through a small acsess hole. be carefull not rip bag bael is in because it shows placemnet of tension pulley and correct direction to wrap belt in.anything past that, im thinkin 18 yrs has been a good run, go for new
Posted on Mar 01, 2008
aborcass
  • 2651 Answers
SOURCE: washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Posted on Apr 29, 2008
My clothes are still dripping wet after a complete cycle.
If the washing machine is not spinning to its regular speed then it can be the cause of wet clothes.If there is any cloth got stuck in between the inner and outer tub then this will slow the speed and this can cause the problem.Also if the washing machine spin motor,if its faulty then it can be the reason for clothes coming wet.Also check the motor coupler,if its cracked or broken this can be the reason of motor not spinning to its full speed. --------- But if all this ----- the motor,the motor coupler and the inner tub and outer tub blockages checked ok.And there is no problem seen then the other possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.So the clothes come out wet,because some amount of water will always enter the washer due to faulty water inlet valve. --------- This are the possibilities that has to be checked and confirmed for the problem to be solved.To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore Washing Machines
Kenmore front loader tub fills with water when not in use
your water fill valves are leaking severely,you should see water dripping in there all the time if its this bad and your clothes should still be wet,not damp even after a good spin after the final spin
Mar 23, 2010 | Kenmore 43142 Front Load Washer
Cloth are still very wet after wash (it used to be very dry and it started happening since last week)
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Feb 07, 2010 | Kenmore Washing Machines
Clothes are to wet after spin cycle
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Kenmore Elite HE3 Washer 2 Hour 'Normal" wash cycle
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My 90 series kenmore wount spin fast enough to get all the water out
Jan 16, 2010 | Kenmore 15864/15862 Top Load Washer
Clothes are dripping wet when I take them out of the washer?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Irt sounds as if your pump is somewhat blocked.
See the following for how to remove the cabinet and check the pump for blockage and/or a problem between the pump and motor.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=2edbaee16223b0927cee89fcc394964e
Dec 22, 2009 | Kenmore 22422 Top Load Washer
HE5 Washer. Water in tub all the time.
your water solenoid is probably not closing completely and letting water by pass. Not sure what your model number is but you can find this part and others at www.Repairclinic.com Good luck.
Apr 20, 2009 | Kenmore HE5
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Mar 02, 2009 | Kenmore 43142 Front Load Washer
Dryers Logo
14 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
